Hide featured image at post (wordpress)
ggastner
ggastner posted this 06 October 2017
I'm using themler on wordpress.
I need the featured image as a thumbnail, but I don't want the featured image shown in the post content.
Which settings do I have to change in themler or in wordpress to get the result I wish?
If this does not work: Is there a possibility - for example - to insert custom css like ".single .post-thumbnail img {display:none;}"?
I tested the plugin "Hide Featured Image". It works, but there is a space left at the beginning of the content text. That looks aweful ...
Please help me to deactivate the display of featured image in the post content.
Anyway: How can I change the style (size etc.) of the featured image shown in the post content in themler?
Thanks for your help an best regards.
Hello, I'm using themler on wordpress. I need the featured image as a thumbnail, but I don't want the featured image shown in the post content. Which settings do I have to change in themler or in wordpress to get the result I wish? If this does not work: Is there a possibility - for example - to insert custom css like ".single .post-thumbnail img {display:none;}"? I tested the plugin "Hide Featured Image". It works, but there is a space left at the beginning of the content text. That looks aweful ... Please help me to deactivate the display of featured image in the post content. Anyway: How can I change the style (size etc.) of the featured image shown in the post content in themler? Thanks for your help an best regards.
Support Team posted this 06 October 2017
Do you mean that you would like to leave the Featured Image on the Blog page only? In this case just switch to the Post template in Themler in the templates list, and then remove the Post Image control from there. Int eh same way you can select it and change its style if needed.
Hello, Do you mean that you would like to leave the Featured Image on the Blog page only? In this case just switch to the Post template in Themler in the templates list, and then remove the Post Image control from there. Int eh same way you can select it and change its style if needed. Sincerely, Nettie, BillionDigital Team
