horz menu
David Hale
David Hale posted this 30 June 2015
When I delete a horz menu from a template, then re-insert a new one, i get a placeholder that says empty. I can never actually see the menu in themler, but it is there when loaded into the cms. How do I make it appear in themler so it can be styled
10 Comments
Support Team posted this 30 June 2015
In general, it is necessary to create a menu in CMS backend, so that it appears in Themler.
Please follow corresponding instructions in order to create Horizontal Menu for Wordpress and Joomla.
Let us know if any questions appear in process.
BIllionDigital Team
Hello, In general, it is necessary to create a menu in CMS backend, so that it appears in Themler. Please follow corresponding instructions in order to [create Horizontal Menu for Wordpress](page:5541) and [Joomla](page:5516). Let us know if any questions appear in process. Sincerely, Nettie, BIllionDigital Team
David Hale
I'm not WP or Joomla... Drupal is the one... But... I mean when I load the drupal default template, it has a visible horz menu in themler out-of-the-box... But if I delete this menu, and add a new one, it goes in, but is not visible in themler for styling purposes.Even after I refresh the cms and everything.
David Hale
it is visible in drupal.. But if I want to style it in themler, it is just a guessing game because it does not show in themler, just the placeholder for it
When you add a new menu control, the menu in Drupal should be assigned to the proper region created by the control. Please follow this article on creating Horizontal Menu in Drupal:
http://answers.themler.com/articles/5542/how-to-create-horizontal-menus-in-drupal
Best regards,
Hello, When you add a new menu control, the menu in Drupal should be assigned to the proper region created by the control. Please follow this article on creating Horizontal Menu in Drupal: http://answers.themler.com/articles/5542/how-to-create-horizontal-menus-in-drupal Best regards, Nettie, BillionDigital Team
David Hale
yes I know that part. It just does not show up in themler even after doing that.. Just an empty region placeholder in themler.
David Hale
It is some other problem....
Support Team posted this 01 July 2015
I have forwarded the issue to our developers and will keep you informed on it.
Hello, I have forwarded the issue to our developers and will keep you informed on it. Sincerely, Nettie, BillionDigital Team
Please perform these additional steps:
  1. After adding a new Horizontal Menu control and applying changes to CMS please go to Drupal Administration >> Configuration >> Development >> Performance and clear caches so that the new region is visible.
  2. In Drupal Administration >> Structure >> Blocks add menu to the newly added region (for example, Horizontal Menu 2). Please note that the menu is added to the basic theme. To be able to customize its appearance in Themler, you may need also to add it to the preview theme.
    For this please click "configure" next to the region and configure it like this:
Hi, Please perform these additional steps: 1. After adding a new Horizontal Menu control and applying changes to CMS please go to **Drupal Administration** >> **Configuration** >> **Development** >> **Performance** and **clear caches** so that the new region is visible. 2. In **Drupal Administration** >> **Structure** >> **Blocks** add menu to the newly added region (for example, Horizontal Menu 2). Please note that the menu is added to the *basic theme*. To be able to customize its appearance in Themler, you may need also to add it to the *preview theme*. For this please click **"configure"** next to the region and configure it like this: !i33.png! Regards, Nettie, BillionDigital Team
David Hale
Is Solution
David Hale posted this 01 July 2015
Indeed that is the answer... Thankyou...
You may wish to add your last post to:
Indeed that is the answer... Thankyou... You may wish to add your last post to: http://answers.themler.com/articles/5542/how-to-create-horizontal-menus-in-drupal
Thank you for the suggestion. We have added this information to the article.
Hello, Thank you for the suggestion. We have added this information to the article.
