Hello, I know I can put multiple Joomla modules in a module position and they will stack on top of each other per my ordering.
What I need is to have the single module position hold multiple modules in a grid like layout so they sit left to right and fill in the position. There will be 13 modules assigned to one position. Essentially I want them to be side by side until they fill the width and then move down below and repeat this effect.
The reason I want this is because they are titled and need to be alphabetical in all views. Currently I have 2 module positions in a 2 column layout and manually order them but when they are responsive the ordering is wrong. If I can have them in one Joomla position just wrapping around and down they will stay in order all the time.
Hello, I know I can put multiple Joomla modules in a module position and they will stack on top of each other per my ordering. What I need is to have the single module position hold multiple modules in a grid like layout so they sit left to right and fill in the position. There will be 13 modules assigned to one position. Essentially I want them to be side by side until they fill the width and then move down below and repeat this effect. The reason I want this is because they are titled and need to be alphabetical in all views. Currently I have 2 module positions in a 2 column layout and manually order them but when they are responsive the ordering is wrong. If I can have them in one Joomla position just wrapping around and down they will stay in order all the time.
