Hello, is there any chance for a quick code tip or some guidance on how to call the slider using AJAX from front-end? The way maybe it's done in preview mode on B.O without needing to implement the whole PHP framework on the front which I find an overkill.
I am a developer, I want to use it in a module like this module: https://addons.prestashop.com/en/sliders-galleries/26873-multi-layer-slider-pro-visual-drag-drop-slider.html
Thanks in advance!
