Help with page layout
stefanos
stefanos posted this 15 November 2017
1. I would like to create the page layout like the image, it's possible to have on each page different image above the menu and the right or left sidebar should start after the image, the image should be 100% of screen without the sidebar.
2. why when I start a new project I have always the pages from my previous project inside the new project?
Hello, 1. I would like to create the page layout like the image, it's possible to have on each page different image above the menu and the right or left sidebar should start after the image, the image should be 100% of screen without the sidebar. [Image][1] 2. why when I start a new project I have always the pages from my previous project inside the new project? [1]: https://prnt.sc/harchd
Support Team posted this 16 November 2017
  1. Themler theme does not create pages. It creates theme with templates which are used for CMS pages depending on its type (home, post, page, blog, default). Therefore, If you add the image to the template it will be displayed on all pages which use this image. You should add the image from CMS somehow. It could be either content (article) or module/widget.
  2. This is because the project is a regular CMS theme. The pages are CMS content. Each new theme does not remove the content created previously and does not create new CMS installation. Themler Desktop is equivalent to your own local or remote CMS installation: obe CMS, same content and different themes.
Hi, 1. Themler theme does not create pages. It creates theme with templates which are used for CMS pages depending on its type (home, post, page, blog, default). Therefore, If you add the image to the template it will be displayed on all pages which use this image. You should add the image from CMS somehow. It could be either content (article) or module/widget. 2. This is because the project is a regular CMS theme. The pages are CMS content. Each new theme does not remove the content created previously and does not create new CMS installation. Themler Desktop is equivalent to your own local or remote CMS installation: obe CMS, same content and different themes. Thank you, Olivia
stefanos
stefanos posted this 16 November 2017
Hi Olivia thanks for your response,
I know that Themler creates the theme and not the pages. Can you tell me please where I can found a detailed documentation how to create a new template like the image above.
Stefanos
Hi Olivia thanks for your response, I know that Themler creates the theme and not the pages. Can you tell me please where I can found a detailed documentation how to create a new template like the image above. Stefanos
Support Team posted this 17 November 2017
You just need Sidebars, Header and Footer controls. That's all. I also explained you that the only way to add the image you're referring to is to use CMS modules/widgets. All controls available under the Insert tab. Simple enable sidebars and add desired controls into the sidebars. The Menu can be added into the Header.
Hi, You just need Sidebars, Header and Footer controls. That's all. I also explained you that the only way to add the image you're referring to is to use CMS modules/widgets. All controls available under the Insert tab. Simple enable sidebars and add desired controls into the sidebars. The Menu can be added into the Header. Thank you, Olivia
stefanos
stefanos posted this 17 November 2017
Hi Olivia,
It's ok, I tried this with using a widget on the top sidebar and it's working.
Hi Olivia, It's ok, I tried this with using a widget on the top sidebar and it's working. Thanks
Support Team posted this 19 November 2017
You are welcome. Let us know if you need our further help.
You are welcome. Let us know if you need our further help. Sincerely, Hella
