I can't find the read more button
oliver.sartor
oliver.sartor posted this 15 November 2017
I can not find the Read More button. In the blog and also in the post area this is not to be found.
The other posts from your forum could not help me! I use the version 355.
I have nowhere the opportunity to insert this button and edit !!
Best regards
Oliver Sartor
Hello, I can not find the Read More button. In the blog and also in the post area this is not to be found. The other posts from your forum could not help me! I use the version 355. I have nowhere the opportunity to insert this button and edit !! Best regards Oliver Sartor
6 Comments
oliver.sartor
oliver.sartor posted this 16 November 2017
Hello, in the blog area and in the post area I can add about the control element, but if I drag it into a range nothing happens. In Screenshot Blog-3 you can see
where I have tried it.
Regards Oliver Sartor
Hello, in the blog area and in the post area I can add about the control element, but if I drag it into a range nothing happens. In Screenshot Blog-3 you can see !Blog-3.jpg! where I have tried it. Regards Oliver Sartor
oliver.sartor
Hallo,
I have one more question. For example, where can I customize the color of the link for the read-more button?
Hallo, I have one more question. For example, where can I customize the color of the link for the read-more button? Regards Oliver Sartor
oliver.sartor
can anybody help me?
Hello, can anybody help me?
oliver.sartor
oliver.sartor posted this 18 November 2017
It would be really helpful, if somebody would give me a returm message!!!
Support Team posted this 20 November 2017
Please check the attached screenshot:
You can customize the color of the text for each state separately.
Please make sure that you added the ReadMore into inside the Posts control and readmore is not disabled in joomla settings.
Hi, Please check the attached screenshot: !readmore-text-settings.png! You can customize the color of the text for each state separately. Please make sure that you added the ReadMore into inside the Posts control and readmore is not disabled in joomla settings. Thank you, Olivia
sitiayuni
sitiayuni posted this 22 September 2025
I had a similar issue before and it took me some time to figure out where the option was. Sometimes small fixes make a big difference, just like in design or even things like corporate gifting Dubai, where details matter the most.
I had a similar issue before and it took me some time to figure out where the option was. Sometimes small fixes make a big difference, just like in design or even things like [corporate gifting Dubai][1], where details matter the most. [1]: https://qasgifts.ae/
