I would like to insert in the template the virtuemart button of function mailRecommend?
I would like to insert in the template the virtuemart button of function mailRecommend?Hi,
Is it built-in VM functionality?
If not but you have php code for button you can add it into the CMS Code control which is available under the Insert tab >> More.
is an option attached to virtuemart to insert mailRecomendar, wanted to know which is php cod to insert in the cms-code of themler
is an option attached to virtuemart to insert mailRecomendar, wanted to know which is php cod to insert in the cms-code of themlerGetting the I wanted the code is the one below:
$link = 'index.php?tmpl=component&option=com_virtuemart&view=productdetails&virtuemart_product_id=' . $this->product->virtuemart_product_id;
echo $this->linkIcon($link . '&format=pdf', 'COM_VIRTUEMART_PDF', 'pdf_button', 'pdf_icon', false);
//echo $this->linkIcon($link . '&print=1', 'COM_VIRTUEMART_PRINT', 'printButton', 'show_printicon');
echo $this->linkIcon($link . '&print=1', 'COM_VIRTUEMART_PRINT', 'printButton', 'show_printicon',false,true,false,'class="printModal"');
$MailLink = 'index.php?option=com_virtuemart&view=productdetails&task=recommend&virtuemart_product_id=' . $this->product->virtuemart_product_id . '&virtuemart_category_id=' . $this->product->virtuemart_category_id . '&tmpl=component';
echo $this->linkIcon($MailLink, 'COM_VIRTUEMART_EMAIL', 'emailButton', 'show_emailfriend', false,true,false,'class="recommened-to-friend"');
Simply insert the CMS Code intol into the Product Details control to the place where you wan to display the links and add the code you provided into the CMS Code control. But you will need to wrap the code into PHP tags:
<?php
[code]
If the appropriate options (print/email) are enabled under the VM settings you will see the links.
