Breezing Forms
crapo
crapo posted this 28 November 2017
For Joomla, I can't seem to get themler to adjust the page Breezing Forms makes. I've tried changing the Home, Blog, and other templates. but no luck. The Form is displayed from a hidden menu item that is a Breezing Form Type.
Stagger Lee posted this 29 November 2017
It is allways under Content" control.
  • Widget - Content - More styles - Input
  • Post - Content - More styles - Input
  • Etc...
It is allways under Content" control. - Widget - Content - More styles - Input - Post - Content - More styles - Input - Etc...
Or right click on menu item, Open, click on form and use More Styles options,.
Support Team posted this 29 November 2017
Please try the suggestions above. If that does not help, provide more details. Like a screen shot showing what exactly you want to style or edit.
Hi, Please try the suggestions above. If that does not help, provide more details. Like a screen shot showing what exactly you want to style or edit. Sincerely, Hella
crapo
Is Solution
crapo posted this 29 November 2017
I found the problem was it is the job of the default template to do the work but it was disable cause there were no pages on the site that it could find. The work around was to make the menu item visible. I moved it to another menu, and then the default template was enabled.
I think the real fix is to alow themler to see hidden menu items.
I found the problem was it is the job of the default template to do the work but it was disable cause there were no pages on the site that it could find. The work around was to make the menu item visible. I moved it to another menu, and then the default template was enabled. I think the real fix is to alow themler to see hidden menu items.
