posted this
30 November 2017
In the image is located inside the Post Image control then this is article intro image. It has Caption field in joomla under the Article >> Images and Links.
If the image is inside the Post Content control, then this is a part of the article content. Therefore the solution on how to add image caption is different and it depends on the WYSIWYG editor you're using in Joomla.
The Post image control which outputs article intro image can be removed. But this will remove all intro images from the blog template.
Themler cannot hide specific parts of the article content on blog template. You can only add readmore before the image in Joomla.
In the image is located inside the **Post Image** control then this is article intro image. It has Caption field in joomla under the Article >> Images and Links.
If the image is inside the **Post Content** control, then this is a part of the article content. Therefore the solution on how to add image caption is different and it depends on the WYSIWYG editor you're using in Joomla.
