Gutenberg
LGWeb
LGWeb posted this 13 December 2017
Themler what are you doing to prepare for Gutenberg? Have you installed the Plugin to begin testing? Do you anticipate all Themler sites will work nicely or will this be a diaster waiting to happen?
Builder Beaver seems to advertise they will be ready ...
I would love some reassurance from you.
Themler what are you doing to prepare for Gutenberg? Have you installed the Plugin to begin testing? Do you anticipate all Themler sites will work nicely or will this be a diaster waiting to happen? Builder Beaver seems to advertise they will be ready ... I would love some reassurance from you.
112 Comments
Support Team posted this 14 December 2017
Unfortunately I cannot guarantee anything but I tested the plugin downloaded from WP plugins portal on my side and resulting page looked the same with Themler and 2017 themes.
Themler theme applies own specific or general styles to the page elements. In some cases they may conflict with the style of the third-party components/plugins. In this case all issues should be investigates separately. If we face some major problems that should be resolved in the theme we'll check them and fix if possible.
Hi, Unfortunately I cannot guarantee anything but I tested the plugin downloaded from WP plugins portal on my side and resulting page looked the same with Themler and 2017 themes. Themler theme applies own specific or general styles to the page elements. In some cases they may conflict with the style of the third-party components/plugins. In this case all issues should be investigates separately. If we face some major problems that should be resolved in the theme we'll check them and fix if possible. Thank you, Olivia
Stagger Lee posted this 15 December 2017
Gutenberg will remove your 2 Themler Metaboxes ( or 3 ? ), and Themler button above TinyMce editor. After New Year sometimes, WP 5.0 stable. They say it will sense non-compatible Metaboxes and force old TinyMce screen. Maybe first few months, I would not belive in it for a second.
If one of the Metaboxes does not work anymore it would not be possible to use custom Page templates.
Gutenberg will remove your 2 Themler Metaboxes ( or 3 ? ), and Themler button above TinyMce editor. After New Year sometimes, WP 5.0 stable. They say it will sense non-compatible Metaboxes and force old TinyMce screen. Maybe first few months, I would not belive in it for a second. If one of the Metaboxes does not work anymore it would not be possible to use custom Page templates.
LGWeb
LGWeb posted this 15 December 2017
I've been using Elementor instead of TinyMCE.. and Elementor claims it will be ready...
I'm getting ready to clone sites and work with Gutenberg.. I have 200 sites and I can't be caught in this disaster.
> Gutenberg will remove your 2 Themler Metaboxes ( or 3 ? ), and Themler button above TinyMce editor. After New Year sometimes, WP 5.0 stable. They say it will sense non-compatible Metaboxes and force old TinyMce screen. Maybe first few months, I would not belive in it for a second. > > If one of the Metaboxes does not work anymore it would not be possible to use custom Page templates. I've been using Elementor instead of TinyMCE.. and Elementor claims it will be ready... I'm getting ready to clone sites and work with Gutenberg.. I have 200 sites and I can't be caught in this disaster.
Support Team posted this 18 December 2017
Not sure what the theme can do if the PLUGIN removes theme metaboxes. And I don't understand why the plugin does it. It is not really good solution.
We'll check this issue when the new Gutenberg version which removes metaboxes will be officially released.
Hi, Not sure what the theme can do if the PLUGIN removes theme metaboxes. And I don't understand why the plugin does it. It is not really good solution. We'll check this issue when the new Gutenberg version which removes metaboxes will be officially released. Thank you, Olivia
LGWeb
LGWeb posted this 18 December 2017
What's alarming to me is that Themler is NOT up on the game.. really? Gutenberg Plugin has been out since last fall... and Divi and Beaver Builder actually attended Wordcamp. You all need to be involved. This is a MAJOR update that will make or break you. Please pass this along to developers.. and please reassure your Themler users that you are keeping up with the latest.
https://wordpress.tv/2017/12/04/matt-mullenweg-state-of-the-word-2017/
Page Editors and Theme Builders will need to code for Gutenberg. It is NOT going away.
What's alarming to me is that Themler is NOT up on the game.. really? Gutenberg Plugin has been out since last fall... and Divi and Beaver Builder actually attended Wordcamp. You all need to be involved. This is a MAJOR update that will make or break you. Please pass this along to developers.. and please reassure your Themler users that you are keeping up with the latest. https://wordpress.tv/2017/12/04/matt-mullenweg-state-of-the-word-2017/ Page Editors and Theme Builders will need to code for Gutenberg. It is NOT going away.
gmmcreative
gmmcreative posted this 25 August 2018
If Themler does not figure this out and allow for coding for Gutenberg, I will be forced to double or even triple my prices by going the 100% custom route. That means I will have to charge a minimum of $5,000 per site. Themler helps keep my costs down, prices down, and shortens development time.
gmmcreative
gmmcreative posted this 27 August 2018
In my reading of Gutenberg, if you install the classic editor plugin now, and when you update to WordPress 5.0, your site will continue to use the classic editor (although you will still have the option to try Gutenberg). It should keep Gutenberg disabled in wordpress 5.0. You can also disable Gutenberg using custom code, but I would recommend the Classic Editor plugin.
orderconfirm
orderconfirm posted this 22 January 2019
That is the advice of Plesk, Just install and enable classic editor plugin now and forget it. Test later, and if you install and enable Gutenberg ramp plugin, you can selectively use different editors with different pages/posts - might be a good way to test with themler, watch it blow up or be good..
Plesk folks also say WP dev has agreed to fully support the classic editor plugin until at least 2022 and probably beyond. So by then Themler should be up to speed with whatever the WP devs roll out . And probably everything will be late anyway. I do not see the value with Gutenberg with the value we have with Themler, don't need to rock our boat with new WP code. I am going to do nothing but the classic editor install asap, and watch what happens over the next 3 years -- and keep reusing with my WP images that run perfectly right now with numerous sophisticated plugins. The plugins I will have to watch as well.
This is a big weird turning point for wordpress, time will tell.
> In my reading of Gutenberg, if you install the classic editor plugin now, and when you update to WordPress 5.0, your site will continue to use the classic editor (although you will still have the option to try Gutenberg). It should keep Gutenberg disabled in wordpress 5.0. You can also disable Gutenberg using custom code, but I would recommend the Classic Editor plugin. > That is the advice of Plesk, Just install and enable classic editor plugin now and forget it. Test later, and if you install and enable Gutenberg ramp plugin, you can selectively use different editors with different pages/posts - might be a good way to test with themler, watch it blow up or be good.. Plesk folks also say WP dev has agreed to fully support the classic editor plugin until at least 2022 and probably beyond. So by then Themler should be up to speed with whatever the WP devs roll out . And probably everything will be late anyway. I do not see the value with Gutenberg with the value we have with Themler, don't need to rock our boat with new WP code. I am going to do nothing but the classic editor install asap, and watch what happens over the next 3 years -- and keep reusing with my WP images that run perfectly right now with numerous sophisticated plugins. The plugins I will have to watch as well. This is a big weird turning point for wordpress, time will tell.
bellaspabangaore1
bellaspabangaore1 posted this 06 March 2024
If you ask any spa lovers about which is best nuru massage near me then answer from each and everyone is bella spa.Yes offering wonderful massage services from many years in bangalore next level service come with expectation and go with results.
If you ask any spa lovers about which is best [nuru massage near me][1] then answer from each and everyone is bella spa.Yes offering wonderful massage services from many years in bangalore next level service come with expectation and go with results. [1]: https://www.bellaspa.in/
br.ya.ntaaron263
br.ya.ntaaron263 posted this 11 March 2024
I like the way you are so enthusiastic about this. money advisor
I like the way you are so enthusiastic about this. [money advisor][1] [1]: https://www.asfinancialplanning.com.au/
tsuclientspecialist
tsuclientspecialist posted this 20 March 2024
Kudos from our insurance copywriting
Kudos from our [insurance copywriting][1] [1]: https://redbirdagents.com/
caseyhenricks92
caseyhenricks92 posted this 20 March 2024
Good job! Amazing post! Showcase of NB Concrete Projects
Good job! Amazing post! [Showcase of NB Concrete Projects][1] [1]: https://www.concretecontractorsnewbraunfelstx.com/concrete-driveways/
poppyplaytime1a
poppyplaytime1a posted this 22 March 2024
Those wishing to showcase their abilities will find vex 3 to be an excellent choice since its design is both tough and visually appealing.
Those wishing to showcase their abilities will find [vex 3][1] to be an excellent choice since its design is both tough and visually appealing. [1]: https://vex-3.com
tsuclientspecialist
tsuclientspecialist posted this 24 March 2024
Kudos from our boli insurance
Kudos from our [boli insurance][1] [1]: https://bankownedlifeinsurance.org/
biowed
biowed posted this 15 April 2024
Your work is very good and I appreciate you and hopping for some more informative posts.
cs2 accounts
Your work is very good and I appreciate you and hopping for some more informative posts. [cs2 accounts][1] [1]: https://buyacsgosmurf.com
tsuclientspecialist
tsuclientspecialist posted this 17 July 2024
Kudos from licensed medicare sales agent
Kudos from [licensed medicare sales agent][1] [1]: https://medicaresalesagent.com/
tsuclientspecialist
tsuclientspecialist posted this 18 July 2024
Kudos for this post. Very inspiring content. For medicare fmo companies visit us at https://medicarefmo.org/
Kudos for this post. Very inspiring content. For [medicare fmo companies][1] visit us at https://medicarefmo.org/ [1]: https://medicarefmo.org/
jw3741eusr
jw3741eusr posted this 18 July 2024
hmm I tried installing the Plugin, I think all Themler sites will work fine it won't be too bad, I update information from top cloud , you can know it and don't worry too much
hmm I tried installing the Plugin, I think all Themler sites will work fine it won't be too bad, I update information from [top cloud][1] , you can know it and don't worry too much [1]: https://www.google.com/
zx861894461
zx861894461 posted this 22 July 2024
明确沟通与需求理解是英文作文修改 http://www.hotessay.net/our_service2.php 机构处理相关问题的关键。客户在提交代写需求时,通常会有具体的要求和期望,如何准确理解和满足这些需求是代写机构需要解决的重要问题。代写机构应建立有效的沟通渠道,确保与客户的沟通顺畅。机构应安排专业的客户经理或项目经理,与客户进行详细的需求分析和沟通,了解客户的具体要求和期望,并记录相关信息。在项目执行过程中,机构应定期与客户沟通,汇报项目进展,听取客户的反馈和意见,及时调整和优化项目方案。通过明确的沟通和需求理解,代写机构可以准确把握客户的需求,提供高质量的代写服务,确保客户满意度。
gypo6hm0sc
gypo6hm0sc posted this 05 August 2024
Show off your musical skills in Friday Night Funkin' with catchy songs.
Show off your musical skills in [Friday Night Funkin][1]' with catchy songs. [1]: https://fnfunkin.io
