I have ordered Themler Pro this month and I had to think several times about whether I wanted to buy it because it looks so good ... Now that I've bought it I already regret it.
I have created and saved a theme for WP several times, but it disappears every time. If you start via WP Themler, everything goes online via the server. Your own desktop version is then not even used. If you use the desktop version, you can start using Themler WP, but it often goes wrong.
The changes are all lost again and I can start again. Also import / export doens't work perfectly. I think that's there is still a lot or work to do. Maybe Windows users have no problems, but I use MAC. And it is very, very slow, because all the things you do goes through the server.
I have ordered Themler Pro this month and I had to think several times about whether I wanted to buy it because it looks so good ... Now that I've bought it I already regret it. I have created and saved a theme for WP several times, but it disappears every time. If you start via WP Themler, everything goes online via the server. Your own desktop version is then not even used. If you use the desktop version, you can start using Themler WP, but it often goes wrong. The changes are all lost again and I can start again. Also import / export doens't work perfectly. I think that's there is still a lot or work to do. Maybe Windows users have no problems, but I use MAC. And it is very, very slow, because all the things you do goes through the server.
