I have set the Popoup Width of the mega menu to "Custom". But if I set any width there are no changes.
Where I wrong?
Where I wrong?
Please make sure the container with menu is not set to Fluid. Try to change the container width or put the menu out the container. This should help.
Hello Thanks, it works.
But if in Theme Layout I set the sheet on Desktop to 1920 px... what happens in monitor with a resolution less than 1920px?
Wich different is there from wide and fluid layout?
If the screen resolution is smaller than the width parameter, the container width will be adjusted to the screen width.
The difference between wide and fluid is that with the wide option your content has that maximum width limitationю
