Please wait...Themler Diagnostics Log
Please create a new support topic at 'http://answers.themler.com' and attach this log to your ticket.
INFO:Version files finded:
INFO: C:\PROGRA~3\Themler\1.0.319.25.ver
INFO:Check free disk space...
INFO:Check Services...
ERROR:Apache service isn't started
INFO:Check Files...
INFO:Check HTTP Server...
INFO:Check url for C:\PROGRA~3\Themler\hd_data\themler_2050777293
INFO: Check is url available: http://localhost:12080/themler_2050777293/startup
ERROR:HTTP request to 'http://localhost:12080/themler_2050777293/startup' throw error:'Unable to connect to the remote server'
INFO: Check is url available: http://localhost:12080/themler_2050777293/wordpress
ERROR:HTTP request to 'http://localhost:12080/themler_2050777293/wordpress' throw error:'Unable to connect to the remote server'
INFO: Check is url available: http://localhost:12080/themler_2050777293/joomla
ERROR:HTTP request to 'http://localhost:12080/themler_2050777293/joomla' throw error:'Unable to connect to the remote server'
INFO:Check INI Files...
INFO:No errors!
======== Content of file C:\Program Files (x86)\Themler\bin_logs\bat_exec.log ========
Program files detected C:\Program Files (x86)
Must be on program files\themler\bin
Volume in drive C is OS
Volume Serial Number is EA96-CE4D
Directory of C:\Program Files (x86)\Themler\bin
01/09/2018 09:53 PM <dir> .
01/09/2018 09:53 PM <dir> ..
01/09/2018 09:52 PM <dir> 7zip
01/09/2018 09:53 PM <dir> apache
01/09/2018 09:53 PM <dir> diagnostics
06/22/2016 07:18 AM 1,402 install-apache.bat
06/22/2016 07:18 AM 2,724 install-mysql.bat
01/09/2018 09:53 PM <dir> mysql
01/09/2018 09:53 PM <dir> php
06/22/2016 07:18 AM 1,730 uninstall-apache.bat
06/22/2016 07:18 AM 1,695 uninstall-mysql.bat
01/09/2018 09:52 PM <dir> _logs
4 File(s) 7,551 bytes
8 Dir(s) 389,662,711,808 bytes free
creating logs just in case
A subdirectory or file C:\ProgramData\Themler already exists.
8 Dir(s) 389,106,360,320 bytes free
======== End of file C:\Program Files (x86)\Themler\bin_logs\bat_exec.log ========
ERROR:Unable to find file C:\ProgramData\Themler\logs\Themler_vbs.log
ERROR:Unable to find file C:\Users\lee cepero\AppData\Local\Themler\Themler_vbs.log
======== Content of file C:\ProgramData\Themler\logs\startup.php.log ========
Thu, 11 Jan 2018 02:34:57 +0000
run from browser = 1
suffix = _2050777293
themlerDataPath = C:/ProgramData/Themler
icPath = C:/ProgramData/Themler/hd_data/themler_2050777293
url = http://127.0.0.1:12080/themler_2050777293
C:/ProgramData/Themler/hd_data/themler_2050777293/startup/1.0.319.25.ver already exists
======== End of file C:\ProgramData\Themler\logs\startup.php.log ========
======== Content of file C:\ProgramData\Themler\logs\apache\error.log ========
AH00558: hthemlerd.exe: Could not reliably determine the server's fully qualified domain name, using fe80::a41b:14:2201:22e0. Set the 'ServerName' directive globally to suppress this message
[Tue Jan 09 21:54:57.067028 2018] [mpm_winnt:notice] [pid 13996:tid 740] AH00455: Apache/2.4.16 (Win32) PHP/5.4.42 configured -- resuming normal operations
[Tue Jan 09 21:54:57.067028 2018] [mpm_winnt:notice] [pid 13996:tid 740] AH00456: Server built: Jul 13 2015 10:37:15
[Tue Jan 09 21:54:57.067028 2018] [core:notice] [pid 13996:tid 740] AH00094: Command line: 'C:\Program Files (x86)\Themler\bin\apache\bin\hthemlerd.exe -d C:/Program Files (x86)/Themler/bin/apache'
[Tue Jan 09 21:54:57.073026 2018] [mpm_winnt:notice] [pid 13996:tid 740] AH00418: Parent: Created child process 14584
[Tue Jan 09 21:54:58.716045 2018] [mpm_winnt:notice] [pid 14584:tid 504] AH00354: Child: Starting 64 worker threads.
======== End of file C:\ProgramData\Themler\logs\apache\error.log ========
Please wait...Themler Diagnostics Log Please create a new support topic at 'http://answers.themler.com' and attach this log to your ticket. INFO:Version files finded: INFO: C:\PROGRA~3\Themler\1.0.319.25.ver INFO:Check free disk space... INFO:Check Services... ERROR:Apache service isn't started INFO:Check Files... INFO:Check HTTP Server... INFO:Check url for C:\PROGRA~3\Themler\hd_data\themler_2050777293 INFO: Check is url available: http://localhost:12080/themler_2050777293/startup ERROR:HTTP request to 'http://localhost:12080/themler_2050777293/startup' throw error:'Unable to connect to the remote server' INFO: Check is url available: http://localhost:12080/themler_2050777293/wordpress ERROR:HTTP request to 'http://localhost:12080/themler_2050777293/wordpress' throw error:'Unable to connect to the remote server' INFO: Check is url available: http://localhost:12080/themler_2050777293/joomla ERROR:HTTP request to 'http://localhost:12080/themler_2050777293/joomla' throw error:'Unable to connect to the remote server' INFO:Check INI Files... INFO:No errors! ======== Content of file C:\Program Files (x86)\Themler\bin\_logs\bat_exec.log ======== Program files detected C:\Program Files (x86) Must be on program files\themler\bin Volume in drive C is OS Volume Serial Number is EA96-CE4D Directory of C:\Program Files (x86)\Themler\bin 01/09/2018 09:53 PM <dir> . 01/09/2018 09:53 PM <dir> .. 01/09/2018 09:52 PM <dir> 7zip 01/09/2018 09:53 PM <dir> apache 01/09/2018 09:53 PM <dir> diagnostics 06/22/2016 07:18 AM 1,402 install-apache.bat 06/22/2016 07:18 AM 2,724 install-mysql.bat 01/09/2018 09:53 PM <dir> mysql 01/09/2018 09:53 PM <dir> php 06/22/2016 07:18 AM 1,730 uninstall-apache.bat 06/22/2016 07:18 AM 1,695 uninstall-mysql.bat 01/09/2018 09:52 PM <dir> _logs 4 File(s) 7,551 bytes 8 Dir(s) 389,662,711,808 bytes free creating logs just in case A subdirectory or file C:\ProgramData\Themler already exists. A subdirectory or file C:\Pr Program files detected C:\Program Files (x86) Must be on program files\themler\bin Volume in drive C is OS Volume Serial Number is EA96-CE4D Directory of C:\Program Files (x86)\Themler\bin 01/09/2018 09:53 PM <dir> . 01/09/2018 09:53 PM <dir> .. 01/09/2018 09:52 PM <dir> 7zip 01/09/2018 09:53 PM <dir> apache 01/09/2018 09:53 PM <dir> diagnostics 06/22/2016 07:18 AM 1,402 install-apache.bat 06/22/2016 07:18 AM 2,724 install-mysql.bat 01/09/2018 09:53 PM <dir> mysql 01/09/2018 09:53 PM <dir> php 06/22/2016 07:18 AM 1,730 uninstall-apache.bat 06/22/2016 07:18 AM 1,695 uninstall-mysql.bat 01/09/2018 09:52 PM <dir> _logs 4 File(s) 7,551 bytes 8 Dir(s) 389,106,360,320 bytes free creating logs just in case A subdirectory or file C:\ProgramData\Themler already exists. A subdirectory or file C:\Pr ======== End of file C:\Program Files (x86)\Themler\bin\_logs\bat_exec.log ======== ERROR:Unable to find file C:\ProgramData\Themler\logs\Themler_vbs.log ERROR:Unable to find file C:\Users\lee cepero\AppData\Local\Themler\Themler_vbs.log ======== Content of file C:\ProgramData\Themler\logs\startup.php.log ======== Thu, 11 Jan 2018 02:34:57 +0000 run from browser = 1 suffix = _2050777293 themlerDataPath = C:/ProgramData/Themler icPath = C:/ProgramData/Themler/hd_data/themler_2050777293 url = http://127.0.0.1:12080/themler_2050777293 C:/ProgramData/Themler/hd_data/themler_2050777293/startup/1.0.319.25.ver already exists ======== End of file C:\ProgramData\Themler\logs\startup.php.log ======== ======== Content of file C:\ProgramData\Themler\logs\apache\error.log ======== AH00558: hthemlerd.exe: Could not reliably determine the server's fully qualified domain name, using fe80::a41b:14:2201:22e0. Set the 'ServerName' directive globally to suppress this message [Tue Jan 09 21:54:57.067028 2018] [mpm_winnt:notice] [pid 13996:tid 740] AH00455: Apache/2.4.16 (Win32) PHP/5.4.42 configured -- resuming normal operations [Tue Jan 09 21:54:57.067028 2018] [mpm_winnt:notice] [pid 13996:tid 740] AH00456: Server built: Jul 13 2015 10:37:15 [Tue Jan 09 21:54:57.067028 2018] [core:notice] [pid 13996:tid 740] AH00094: Command line: 'C:\\Program Files (x86)\\Themler\\bin\\apache\\bin\\hthemlerd.exe -d C:/Program Files (x86)/Themler/bin/apache' [Tue Jan 09 21:54:57.073026 2018] [mpm_winnt:notice] [pid 13996:tid 740] AH00418: Parent: Created child process 14584 AH00558: hthemlerd.exe: Could not reliably determine the server's fully qualified domain name, using fe80::a41b:14:2201:22e0. Set the 'ServerName' directive globally to suppress this message AH00558: hthemlerd.exe: Could not reliably determine the server's fully qualified domain name, using fe80::a41b:14:2201:22e0. Set the 'ServerName' directive globally to suppress this message [Tue Jan 09 21:54:58.716045 2018] [mpm_winnt:notice] [pid 14584:tid 504] AH00354: Child: Starting 64 worker threads. ======== End of file C:\ProgramData\Themler\logs\apache\error.log ========
