Vertical menu
provaznik
provaznik posted this 24 January 2018
I use Joomla 3.8.3 and Themler and I try add a vertical menu into my website. But I cant find how to add a vertical menu. In your sites is some answer https://answers.themler.io/articles/5109/vertical-menu, but I cant PW.
Thanks for your help.
Daku
Hello, I use Joomla 3.8.3 and Themler and I try add a vertical menu into my website. But I cant find how to add a vertical menu. In your sites is some answer https://answers.themler.io/articles/5109/vertical-menu, but I cant PW. Thanks for your help. Daku ![C:\Users\Kůrková\Desktop\Menu.png][1] [1]: http://C:%5CUsers%5CK%C5%AFrkov%C3%A1%5CDesktop%5CMenu.png
Support Team posted this 24 January 2018
Hi Daku,
There is a link to another article which might be more of a use
https://answers.themler.io/articles/6643/how-to-create-vertical-menus-in-joomla
Did you already have a look at it ?
Ivan
Hi Daku, There is a link to another article which might be more of a use https://answers.themler.io/articles/6643/how-to-create-vertical-menus-in-joomla Did you already have a look at it ? Thanks, Ivan
provaznik
provaznik posted this 01 February 2019
Hi Ivan,
what is it PW in PW >> Styles >> Vertical Menu?
Thank you, Daku
Hi Ivan, what is it PW in PW >> Styles >> Vertical Menu? Thank you, Daku
Support Team posted this 02 February 2019
Hello Daku,
There is not a property window (PW) in a new Themler interface but tabs with the ribbon on the top. The Vertical Menu can be styled from the Design tab >> More Styles >> Vertical Menu or if you have the menu already added, just select it and edit the styles in the Vertical Menu tab.
Hello Daku, There is not a property window (PW) in a new Themler interface but tabs with the ribbon on the top. The Vertical Menu can be styled from the Design tab >> More Styles >> Vertical Menu or if you have the menu already added, just select it and edit the styles in the Vertical Menu tab. Sincerely, Nettie
