post date: only date, no time
macais
macais posted this 26 January 2018
Hello!
I use Joomla 3.8 and generated my template.
the post date is shown like: 18. September 2017, but no time.
I would like to have ist like this : 18. September 2017 - 17:45
Would be nice, if someone could help. thx
Hello! I use Joomla 3.8 and generated my template. the post date is shown like: 18. September 2017, but no time. I would like to have ist like this : 18. September 2017 - 17:45 Would be nice, if someone could help. thx
Vitaliy WD
Vitaliy WD posted this 26 January 2018
Hello.
Check this manual: https://www.ostraining.com/blog/joomla/change-joomla-s-date-format/
But please note that for Joomla 3 date format is DATE_FORMAT_LC3 (not DATE_FORMAT_LC2).
Hello. Check this manual: https://www.ostraining.com/blog/joomla/change-joomla-s-date-format/ But please note that for Joomla 3 date format is DATE_FORMAT_LC3 (not DATE_FORMAT_LC2).
macais
macais posted this 30 January 2018
Hello!
Thanks for your answer.
This works fine, when I need an override for all.
But I tried to have this (Published: 24 January 2018 11:52) only in Post date.
Hello! Thanks for your answer. This works fine, when I need an override for all. But I tried to have this (Published: 24 January 2018 11:52) only in Post date. Thanks
Support Team posted this 31 January 2018
As alternative you can try to output the date manually using CMS Code control. For example:
<?php echo JHtml::_('date', $item->date, 'd F Y H:i'); ?>
This is regular joomla code.
Hi, As alternative you can try to output the date manually using CMS Code control. For example: `<?php echo JHtml::_('date', $item->date, 'd F Y H:i'); ?>` This is regular joomla code. Thank you, Olivia
macais
macais posted this 08 February 2018
Hello!
Thanks, this works fine!
Hello! Thanks, this works fine!
Support Team posted this 09 February 2018
souacz
souacz posted this 1 weeks ago
&lt;?php echo jhtml::_(&#39;date&#39;, $item-?&gt;date, 'd F Y H:i'); ?>
How can I put the code?
> Hi, > > As alternative you can try to output the date manually using CMS Code control. For example: > `&lt;?php echo jhtml::_(&#39;date&#39;, $item-?&gt;date, 'd F Y H:i'); ?>` > > This is regular joomla code. > > Thank you, > Olivia How can I put the code?
Support Team posted this 5 days ago
Please open the theme in Themler and in the Insert tab select CMS Code control, add it to the page.
Then click Edit CMS Code on the ribbon in the CMS Code tab and put the code below in there.
I have noticed, the code was copied incorrectly, it should look like
Hello, Please open the theme in Themler and in the Insert tab select CMS Code control, add it to the page. Then click Edit CMS Code on the ribbon in the CMS Code tab and put the code below in there. I have noticed, the code was copied incorrectly, it should look like `<?php echo JHtml::_('date', $item->date, 'd F Y H:i'); ?>` Sincerely, Nettie
