Edit Button Joomla inactive 3.8.5
butterfly_webdesign
butterfly_webdesign posted this 07 February 2018
Hello, my Edit Button on a downloaded Themler-Joomla-Template is grey.
I do the permission things
enter image description here
but its still grey
Hello, my Edit Button on a downloaded Themler-Joomla-Template is grey. I do the permission things ![enter image description here][1] but its still grey [1]: http://www.butterfly-webdesign.de/rausch/media/permission.jpg
Support Team posted this 07 February 2018
If "Edit Template" button is disable in Joomla admin panel and you cannot start Themler please try the following solution:
open <theme_name>/app/classes/Config.php file
find the line
$editor = JRequest::getVar('editor', '');
add the following line right before the line above:
JHtml::_ ( 'behavior.modal' ); // for SqueezeBox
Hi, If "Edit Template" button is disable in Joomla admin panel and you cannot start Themler please try the following solution: open `<theme_name>/app/classes/Config.php` file find the line $editor = JRequest::getVar('editor', ''); add the following line right before the line above: JHtml::_ ( 'behavior.modal' ); // for SqueezeBox Sincerely, Hella
butterfly_webdesign
Thank you very much. It works fine for me.
You're welcome :)
Ivan
Hi, You're welcome :) Please let us know if you have any further questions. Thanks, Ivan
peggybaussart
peggybaussart posted this 08 October 2018
I inserted the line of code into the config.php file of the template. The "edit template" button becomes active, but I have an error message when I click on "edit template" button.
Warning: printf(): Too few arguments in /homepages/27/d515275597/htdocs/hetm/templates/interiology/app/classes/Helper.php on line 166
thank you for helping me
Peggy
Hi, I inserted the line of code into the config.php file of the template. The "edit template" button becomes active, but I have an error message when I click on "edit template" button. Warning: printf(): Too few arguments in /homepages/27/d515275597/htdocs/hetm/templates/interiology/app/classes/Helper.php on line 166 thank you for helping me Peggy
Support Team posted this 08 October 2018
Hello Peggy,
We have answered you in the private topic.
Hello Peggy, We have answered you in the private topic. Sincerely, Nettie
MercurioWeb WebStudio
MercurioWeb WebStudio posted this 02 July 2019
Hello Peggy,
HI, I have the same problem, how can I solve it?
> Hello Peggy, > > We have answered you in the private topic. > > Sincerely, > Nettie HI, I have the same problem, how can I solve it?
Support Team posted this 09 July 2019
Have you tried the solution with editing the code?
Hello, Have you tried the solution with editing the code? Sincerely, Nettie
