Wordpress Plugin Overrides
bsjelin
bsjelin posted this 16 February 2018
Hello - I am having issues when adding plugin theme overrides into my themler directory in Wordpress.
I am customizing Event Calendar for Wordpress and per their instructions, I'm supposed to add a folder in the root of my theme directory and add my template overrides there.
/wp-content/themes/your-theme/tribe-events/list/content.php
However, anytime I do this, Themler wipes out half of the files in the template folder after saving or making a change to the template and then the entire theme is rendered unusable and I have to start over again with uploading a new blank template. Is this a known issue? Is there another way or another directory I'm supposed to use for this purpose? Thanks in advance.
Hello - I am having issues when adding plugin theme overrides into my themler directory in Wordpress. I am customizing Event Calendar for Wordpress and per their instructions, I'm supposed to add a folder in the root of my theme directory and add my template overrides there. ***/wp-content/themes/your-theme/tribe-events/list/content.php*** However, anytime I do this, Themler wipes out half of the files in the template folder after saving or making a change to the template and then the entire theme is rendered unusable and I have to start over again with uploading a new blank template. Is this a known issue? Is there another way or another directory I'm supposed to use for this purpose? Thanks in advance.
8 Comments
bsjelin
Yea I've done it 3 times so far and I've lost my template every time haha - soooo I'll wait to see if there is a workaround that you guys have for me. I'm not sure what else I can do other than editing the plugins files directly, but they'll get overwritten on the first plugin update.
bsjelin
I also receive this error frequently during saves or changes to a template. Dreamhost can not see anything wrong with the server/hosting settings and the ONLY plugins I have installed are Event Calendar and the Themler plugin.
I also receive this error frequently during saves or changes to a template. Dreamhost can not see anything wrong with the server/hosting settings and the ONLY plugins I have installed are Event Calendar and the Themler plugin.!1.JPG!
Support Team posted this 19 February 2018
  1. When you edit the theme folder after exporting, please note that all the changes will be overridden on the next theme save/publish or update operation. As I understand, you have already seen this problem. I'm not sure what to suggest you. Maybe altering the plug-in code will be better as probably they do not update the plug-in code so many times as you update the theme.
  2. Regarding the 404 issue. It may be indeed related to the plug-ins or permissions. So try to switch your WP plug-ins and run Themler. If that is not the case, then also check the permissions, should be like in this article:
    http://answers.themler.io/articles/65488/troubleshooting-read-first
Hi, 1. When you edit the theme folder after exporting, please note that all the changes will be overridden on the next theme save/publish or update operation. As I understand, you have already seen this problem. I'm not sure what to suggest you. Maybe altering the plug-in code will be better as probably they do not update the plug-in code so many times as you update the theme. 2. Regarding the 404 issue. It may be indeed related to the plug-ins or permissions. So try to switch your WP plug-ins and run Themler. If that is not the case, then also check the permissions, should be like in this article: http://answers.themler.io/articles/65488/troubleshooting-read-first Sincerely, Hella
bsjelin
bsjelin posted this 19 February 2018
So there's no workaround to this other than "dont update the plugin"? lol - has nobody else run into this issue? Its fairly common to use the template to override third party plugins even in Joomla as well as wordpress.
Support Team posted this 20 February 2018
We provide the tool to override some CSS code or also some other functionality if there is no need to insert the code into some specific location. So when you need to override some CSS, JS or PHP code, you can insert it under the Home >> Settings >> Additonal CSS / Additional HEAD HTML / Additional CMS Code correspondingly.
Hi, We provide the tool to override some CSS code or also some other functionality if there is no need to insert the code into some specific location. So when you need to override some CSS, JS or PHP code, you can insert it under the Home >> Settings >> Additonal CSS / Additional HEAD HTML / Additional CMS Code correspondingly. Sincerely, Hella
alexarafatonline
alexarafatonline posted this 21 June 2025
I feel your pain — Themler can be finicky with overrides! I had a similar issue while customizing a plugin, and it kept wiping my changes. Have you tried using a child theme instead? That way, your overrides stay safe even if Themler acts up. Speaking of precision and reliability, this reminds me of the Damascus knives from Jun Knives — each one is hand-forged with flawless craftsmanship, just like how we wish our themes would behave! Their blades never fail, whether in the kitchen or outdoors. Maybe we need that same level of perfection in our WordPress setups!
I feel your pain — Themler can be finicky with overrides! I had a similar issue while customizing a plugin, and it kept wiping my changes. Have you tried using a child theme instead? That way, your overrides stay safe even if Themler acts up. Speaking of precision and reliability, this reminds me of the [Damascus knives][1] from Jun Knives — each one is hand-forged with flawless craftsmanship, just like how we wish our themes would behave! Their blades never fail, whether in the kitchen or outdoors. Maybe we need that same level of perfection in our WordPress setups! [1]: https://junknives.com/collections/damascus-knives
maazkhalid092
maazkhalid092 posted this 21 June 2025
Breathing cleaner air reduces the risk of asthma, allergies, and respiratory issues. Andrew and Sons Air Duct Cleaning, LLC focuses on improving your indoor air environment by Chimney Cleaning removing contaminants and allergens. Their service is ideal for families with children, pets, or health-sensitive individuals.
Breathing cleaner air reduces the risk of asthma, allergies, and respiratory issues. Andrew and Sons Air Duct Cleaning, LLC focuses on improving your indoor air environment by [Chimney Cleaning][1] removing contaminants and allergens. Their service is ideal for families with children, pets, or health-sensitive individuals. [1]: https://andrewandsonsadc.com/chimney-sweep/
maazkhalid092
Starting your day with a clear intention can dramatically improve focus and mental clarity. It is a simple practice that helps align your actions with your goals. Rather stockbroker than drifting through the day on autopilot, setting an intention grounds you in purpose. This can be anything from being more patient, staying productive, or simply choosing to remain calm in stressful situations. As the day progresses, you will be more likely to act in line with your intention, resulting in greater personal satisfaction.
Starting your day with a clear intention can dramatically improve focus and mental clarity. It is a simple practice that helps align your actions with your goals. Rather [stockbroker][1] than drifting through the day on autopilot, setting an intention grounds you in purpose. This can be anything from being more patient, staying productive, or simply choosing to remain calm in stressful situations. As the day progresses, you will be more likely to act in line with your intention, resulting in greater personal satisfaction. [1]: http://royalcapitalbd.com/
