Will themler be supporting joomla 4.
Will themler be supporting joomla 4.Hi,
We'll look into the Joomla 4 version after its official release. Our developers will look into it in case of any issues.
Hi Hella
I find it a bit hard to believe you don't know whether it will be supported or not
As a customer who has created a great deal of sites using themler for joomla.
It is pretty major for me to know if you will continue to support Joomla.
I note that development on all of your products appear to have stalled.
UPage doesn't seem to be doing much either.
Is this company close to finishing up?
David
Hi Hella I find it a bit hard to believe you don't know whether it will be supported or not As a customer who has created a great deal of sites using themler for joomla. It is pretty major for me to know if you will continue to support Joomla. I note that development on all of your products appear to have stalled. UPage doesn't seem to be doing much either. Is this company close to finishing up? DavidHi,
I didn't say that we won't support Joomla 4. If you are working with our products for a long time, you know that we support all the new releases of major CMSs (WP, Joomla). But we also wait every time for the official release of the new CMS version to see if it is not compatible with our themes and then do some modifications to support it. So as I said, wait till the official Joomla 4 release, then our themes will be tested and we'll look forward for the results.
You also didn't confirm that you will be.
So your saying Yes you will be supporting it.
David
You also didn't confirm that you will be. So your saying Yes you will be supporting it. DavidHi,
We plan to support Joomla 4.
Closer to the joomla 4 release date, it will be clear whether we need a separate export for joomla 4 or not. In case of complete incompatibility of joomla 3 themes with joomla 4 we will need to create a new export. This will take a time. But joomla is one of the major CMS and we plan support all its further versions.
