Themler Beta v.441 Update (15-February-2018)
Support Team posted this 21 February 2018
Hi everyone!
The new Themler version is 441.
Here is a list of fixes included in this Themler update:
General
  • Fixed the issue with transition effect in the menu;
  • Fixed the Function create_function() is deprecated error in PHP 7.2.
WordPress and WooCommerce
  • Fixed the issue with the Show widget on option for the Products template;
  • Fixed the problem with the Use of undefined constant WC_VERSION notice;
  • Fixed the issue with highlighting of the Events Calendar plug-in menu items;
  • Added the Apply menu item tag filter option to disable HTML-tag removing from the menu items (the flag icon will now work with the WPML plug-in);
  • Fixed the layout issues with the invisible products;
  • Fixed the issue with startup of Themler with the WP Admin Theme CD plug-in;
  • Fixed the problem with the product categories display in WC 3.3;
  • Fixed the menu display issues with the UberMenu plug-in;
Joomla and VirtueMart
  • Fixed the Call to a member function get() on a non-object error for the non-authorized users;
  • Fixed the issue with the Show products of the selected category option;
  • Fixed the 404 issue when pressing the Install plug-ins button in the active theme;
PrestaShop 1.7 Beta 2
  • Added the Hook Right Column control;
  • Added the Hook control that will add the hook into your theme with the desired hook name;
  • Fixed Themler warnings when working with CartLink;
  • Fixed the issue with updating the products amount in the cart;
  • Faceted Search is now working fine;
  • Fixed the issue with switching to the Shopping Cart template;
  • Fixed the theme archivation issues for some particular php.ini configurations;
  • Some other minor fixes.
Themler Team
Hi everyone! The new Themler version is 441. Here is a list of fixes included in this Themler update: [post:156153] Sincerely, Themler Team
20 Comments
pdg.design
pdg.design posted this 21 February 2018
We can to ask for any new functions in Themler? May be in feature?
Vitaliy WD
Vitaliy WD posted this 21 February 2018
Thank you for fixes.
blank_themler_joomla_theme is now updated to 441?
Thank you for fixes. `blank_themler_joomla_theme` is now updated to 441?
cm
cm posted this 22 February 2018
How about Drupal updates? Fixes..
Support Team posted this 22 February 2018
If you have any suggestions please provide then via our support system.
Currently 441 version is beta update. We update blank themes to the stable releases only.
Unfortunately this update does not include Drupal fixes.
Hi, If you have any suggestions please provide then via our support system. Currently 441 version is beta update. We update blank themes to the stable releases only. Unfortunately this update does not include Drupal fixes. Thank you, Olivia
philippe.pphantom
philippe.pphantom posted this 22 February 2018
and for drupal no correction ? Olivia i wait for your anwser for the Drupal bugs
Administración web
Administración web posted this 22 February 2018
Muchas gracias. Siempre es bueno saber que se mejoran errores y se adaptan aspectos a las nuevas versiones.
También sería genial que añadieran nuevas "funciones" y nuevos "controles" a Themler de vez en cuando, así se anima mucho más uno a seguir contribuyendo con Themler.
Gracias.
Muchas gracias. Siempre es bueno saber que se mejoran errores y se adaptan aspectos a las nuevas versiones. También sería genial que añadieran nuevas "**funciones**" y nuevos "**controles**" a Themler de vez en cuando, así se anima mucho más uno a seguir contribuyendo con Themler. Gracias.
philippe.pphantom
philippe.pphantom posted this 23 February 2018
no more contract with your Drupal developper ?
Will Themler abandon Drupal? Your lack of explanation is fraught with meaning and in all a miscommunication ..
> and for drupal no correction ? Olivia i wait for your anwser for the Drupal bugs no more contract with your Drupal developper ? Will Themler abandon Drupal? Your lack of explanation is fraught with meaning and in all a miscommunication ..
philippe.pphantom
Normal to write that without any explanation regarding all the bugs ongoing ? Like if Themler has no responsability on this situation ...
> Hi, > > > > **Unfortunately this update does not include Drupal fixes.** > > Thank you, > Olivia Normal to write that without any explanation regarding all the bugs ongoing ? Like if Themler has no responsability on this situation ...
stryjek-www
stryjek-www posted this 24 February 2018
gdzie pobrać themler 441?
Real_Gabe
Real_Gabe posted this 24 February 2018
Hi!
The style.min.css problem is sill exist, I reported it again!
"Hi!
The themler generated style.min.css messing up the Drupal 7 site's look.
Slider not appearing, icons not appearing just some weird characters instead and more.
This problem appeard from v418.
I reported this issue and what causes it but not yet fixed!
It seems there are not the needed codes are in the style.min.css because it is not the minified version of the style.css, instead it is the code of animate.css
I included everything in the attached zip file.
Thank You!"
Hi! The style.min.css problem is sill exist, I reported it again! **"Hi! The themler generated style.min.css messing up the Drupal 7 site's look. Slider not appearing, icons not appearing just some weird characters instead and more.** **This problem appeard from v418. I reported this issue and what causes it but not yet fixed!** **It seems there are not the needed codes are in the style.min.css because it is not the minified version of the style.css, instead it is the code of animate.css I included everything in the attached zip file. Thank You!"**
philippe.pphantom
philippe.pphantom posted this 25 February 2018
Hi!
"Hi!
Thank You!"
exactly some issue reported to the support without any kind of anwser
> Hi! > > The style.min.css problem is sill exist, I reported it again! > > **"Hi! > The themler generated style.min.css messing up the Drupal 7 site's look. > Slider not appearing, icons not appearing just some weird characters instead and more.** > > **This problem appeard from v418. > I reported this issue and what causes it but not yet fixed!** > > **It seems there are not the needed codes are in the style.min.css because it is not the minified version of the style.css, instead it is the code of animate.css > I included everything in the attached zip file. > Thank You!"** exactly some issue reported to the support without any kind of anwser
Real_Gabe
Real_Gabe posted this 25 February 2018
Hi!
"Hi!
Thank You!"
Make a copy of style.css and rename it to style.min.css and overwrite the original style.min.css with it.
You can make your own minified verison on this site if you want: https://www.cleancss.com/css-minify
You have to do it all the time when you generate the theme.
> > Hi! > > > > The style.min.css problem is sill exist, I reported it again! > > > > **"Hi! > > The themler generated style.min.css messing up the Drupal 7 site's look. > > Slider not appearing, icons not appearing just some weird characters instead and more.** > > > > **This problem appeard from v418. > > I reported this issue and what causes it but not yet fixed!** > > > > **It seems there are not the needed codes are in the style.min.css because it is not the minified version of the style.css, instead it is the code of animate.css > > I included everything in the attached zip file. > > Thank You!"** > > exactly some issue reported to the support without any kind of anwser Make a copy of style.css and rename it to style.min.css and overwrite the original style.min.css with it. You can make your own minified verison on this site if you want: https://www.cleancss.com/css-minify You have to do it all the time when you generate the theme.
stryjek-www
stryjek-www posted this 25 February 2018
Potrzebuje themler 441 dla prestashop 1.7 beta gdzie go pobrać
philippe.pphantom
philippe.pphantom posted this 26 February 2018
Hi!
"Hi!
Thank You!"
yes thanks that also work it to copy the content of /font into /css/font/
Be frankly i call that a big bug that should be corrected
> > > Hi! > > > > > > The style.min.css problem is sill exist, I reported it again! > > > > > > **"Hi! > > > The themler generated style.min.css messing up the Drupal 7 site's look. > > > Slider not appearing, icons not appearing just some weird characters instead and more.** > > > > > > **This problem appeard from v418. > > > I reported this issue and what causes it but not yet fixed!** > > > > > > **It seems there are not the needed codes are in the style.min.css because it is not the minified version of the style.css, instead it is the code of animate.css > > > I included everything in the attached zip file. > > > Thank You!"** > > > > exactly some issue reported to the support without any kind of anwser > > Make a copy of style.css and rename it to style.min.css and overwrite the original style.min.css with it. > You can make your own minified verison on this site if you want: https://www.cleancss.com/css-minify > > You have to do it all the time when you generate the theme. yes thanks that also work it to copy the content of /font into /css/font/ Be frankly i call that a big bug that should be corrected
Support Team posted this 27 February 2018
Unfortunately this update does not include fixes for Drupal.
The issue with style.min.css file usually can be solved by using SAVE option instead of PUBLISH. The SAVE option creates not minified file which should work ok. This is related to images and icons also. If you export the theme Themler PUBLISHES the theme. Therefore if you need to transfer theme to the new server you need to SAVE theme and take the theme folder from the current server and upload manually to the new server by FTP. This should work,
The theme for PrestaShop 1.7 can be updated in a usual way using Update option in the Themler. We'll update blank themes to the new version later tomorrow.
Hi, Unfortunately this update does not include fixes for Drupal. The issue with style.min.css file usually can be solved by using SAVE option instead of PUBLISH. The SAVE option creates not minified file which should work ok. This is related to images and icons also. If you export the theme Themler PUBLISHES the theme. Therefore if you need to transfer theme to the new server you need to SAVE theme and take the theme folder from the current server and upload manually to the new server by FTP. This should work, The theme for PrestaShop 1.7 can be updated in a usual way using Update option in the Themler. We'll update blank themes to the new version later tomorrow. Thank you, Olivia
Real_Gabe
Real_Gabe posted this 28 February 2018
So I made a very new Drupal theme with the "Create new theme" button on the home screen. Its name is Untitled1. It's the default theme, I did not edited it, not saved, not saved&publish. Its Themler version is v355.
Then exported it first with the "Include Themler for customizing this theme" enabled, then exported again it with this option disabled.
There is the style.min.css file in both versions (with Themler and without Themler)!
I say it again "Save" and "Save&Publish" were not used!
I created a new default theme and immediately exported it with the "Export" button on the home tab.
If Themler automaticaly use "Save" or "Save&Publish" method when I hit the Export button, we (the users) nothing can do to avoid of creating style.min.css file!
It's obvious we (the users) can't do anything to avoid the generation of the style.min.css file!
Then..
I updated the theme to the latest version (v411 beta) then I repeat the steps above.
Immediately exported the unedited (just updated) theme with the "Include Themler for customizing this theme" enabled, then exported again it with this option disabled.
Obviously there is the style.min.css file in both theme.
I think when I updating the theme, Themler is using one of the saving method which obviously we (the users) cannot avoid, but it is irrelevant cos the style.min.css is generated by Themler by default before the update, before using any kind of saving methods by the user.
The results:
v355 works fine
v411 has problems (missing icon for the "back to top" button", missing icons for the slider's next and previous buttons, and I think it would be more if I edit the theme and put some more things in it)
then I overwrote the v411's style.min.css file with v355's one on the live site and magically everything is fine!!!!!!!!!!!!!!!!!!!!!!!!!!
So in v418 you guys made some changes that makes a messed up style.min.css file!
But for the for completeness, I tested that you said:
"Therefore you just need to save the theme instead of publish. If you need to transfer the theme to the new server please SAVE the theme and download the theme folder from the hard drive:
c:\ProgramData\Themler\hd_data\themler_[numbers]\drupal\sites\all\themes\"
So I just "SAVED" not "SAVE&PUBLISHED", and closed Themler. I looked into the theme's css folder on the path above and there was no style.min.css file! I copied the Untilted1 theme from the location above and uploaded to the live site and it's working fine.
So I looked into other theme's css folder and the style.min.css file was there.
I opened the project with themler and saved it and the style.min.css file disappeared from the folder... but when I hit the export button the style.min.css file created again and it's created in the exported theme too.
When I closed Themler the style.min.css file still remain in the css folder on the hard drive (c:\ProgramData\Themler\hd_data\themler_[numbers]\drupal\sites\all\themes\").
It's only disappear if I save the theme, but I can't export the theme without a style.min.css file.
So I can only use the theme from the hard drive, can not the exported one, and I have to avoid the export button if I don't want style.min.css file in the hard drive's theme.
It's not good, it's not a solution!
Why I have to aware such things and why I have to dig up the theme from a hidden system folder when there is an export button which worked fine before v418 even with style.min.css in the exported theme?
Please fix this!
Please put the two version's (v355 and v411) style.min.css files in a diffchecker like https://www.diffchecker.com/diff and check what are the differences in the two codes and find which changes causing the problems!
Thats not my problem only, others has this problem too!
Thank You
So I made a very new Drupal theme with the "**Create new theme**" button on the home screen. Its name is **Untitled1**. **It's the default theme, I did not edited it, not saved, not saved&publish**. Its Themler version is **v355**. Then exported it first with the "Include Themler for customizing this theme" enabled, then exported again it with this option disabled. There is the style.min.css file in both versions (with Themler and without Themler)! I say it again "Save" and "Save&Publish" were not used! I created a new default theme and immediately exported it with the "Export" button on the home tab. If Themler automaticaly use "Save" or "Save&Publish" method when I hit the Export button, we (the users) nothing can do to avoid of creating style.min.css file! It's obvious we (the users) can't do anything to avoid the generation of the style.min.css file! **Then..** I updated the theme to the latest version (v411 beta) then I repeat the steps above. Immediately exported the unedited (just updated) theme with the "Include Themler for customizing this theme" enabled, then exported again it with this option disabled. Obviously there is the style.min.css file in both theme. I think when I updating the theme, Themler is using one of the saving method which obviously we (the users) cannot avoid, but it is irrelevant cos the style.min.css is generated by Themler by default before the update, before using any kind of saving methods by the user. **The results:** ***v355*** works fine **v411** has problems (missing icon for the "back to top" button", missing icons for the slider's next and previous buttons, and I think it would be more if I edit the theme and put some more things in it) then I overwrote the v411's style.min.css file with v355's one on the live site and magically everything is fine!!!!!!!!!!!!!!!!!!!!!!!!!! So in v418 you guys made some changes that makes a messed up style.min.css file! But for the for completeness, I tested that you said: "Therefore you just need to save the theme instead of publish. If you need to transfer the theme to the new server please SAVE the theme and download the theme folder from the hard drive: c:\ProgramData\Themler\hd_data\themler_[numbers]\drupal\sites\all\themes\" So I just "SAVED" not "SAVE&PUBLISHED", and closed Themler. I looked into the theme's css folder on the path above and there was no style.min.css file! I copied the Untilted1 theme from the location above and uploaded to the live site and it's working fine. So I looked into other theme's css folder and the style.min.css file was there. I opened the project with themler and saved it and the style.min.css file disappeared from the folder... but when I hit the export button the style.min.css file created again and it's created in the exported theme too. When I closed Themler the style.min.css file still remain in the css folder on the hard drive (c:\ProgramData\Themler\hd_data\themler_[numbers]\drupal\sites\all\themes\"). It's only disappear if I save the theme, but I can't export the theme without a style.min.css file. **So I can only use the theme from the hard drive, can not the exported one, and I have to avoid the export button if I don't want style.min.css file in the hard drive's theme. It's not good, it's not a solution!** **Why I have to aware such things and why I have to dig up the theme from a hidden system folder when there is an export button which worked fine before v418 even with style.min.css in the exported theme? Please fix this!** Please put the two version's (v355 and v411) style.min.css files in a diffchecker like https://www.diffchecker.com/diff and check what are the differences in the two codes and find which changes causing the problems! Thats not my problem only, others has this problem too! Thank You
Support Team posted this 28 February 2018
Real_Gabe,
Yes, this is not solution but a workaround and it works ok.
When you PUBLISH theme Themler creates minified style.min.css file which has the problem with paths of some images. The EXPORT process includes PUBLISHING. That's why the exported theme contains style.min.css file.
We'll fix the issue with minified style sheet. Currently please use the workaround with SAVE.
We apologize for the inconvenience.
Real_Gabe, Yes, this is not solution but a workaround and it works ok. When you PUBLISH theme Themler creates minified style.min.css file which has the problem with paths of some images. The EXPORT process includes PUBLISHING. That's why the exported theme contains style.min.css file. We'll fix the issue with minified style sheet. Currently please use the workaround with SAVE. We apologize for the inconvenience. Thank you, Olivia
philippe.pphantom
philippe.pphantom posted this 01 March 2018
can we have an explanation why no drupal update, why you don't anwser even on private msg ? 48$ for a product that no work ...
> Hi, > > Unfortunately this update does not include fixes for Drupal. > The issue with style.min.css file usually can be solved by using SAVE option instead of PUBLISH. The SAVE option creates not minified file which should work ok. This is related to images and icons also. If you export the theme Themler PUBLISHES the theme. Therefore if you need to transfer theme to the new server you need to SAVE theme and take the theme folder from the current server and upload manually to the new server by FTP. This should work, > > > The theme for PrestaShop 1.7 can be updated in a usual way using Update option in the Themler. We'll update blank themes to the new version later tomorrow. > > Thank you, > Olivia can we have an explanation why no drupal update, why you don't anwser even on private msg ? 48$ for a product that no work ...
Support Team posted this 01 March 2018
Unfortunately we have temporary delays with Drupal fixes related to technical problems. We hope that the fix for this problem (missing images and icons) will appear in the near future. In the meantime please use the suggested workaround: use SAVE option instead of publish. If you need to export the theme please SAVE it and download theme folder from the hard drive or server manually. The export functions does PUBLISH before exporting the theme.
Hi, Unfortunately we have temporary delays with Drupal fixes related to technical problems. We hope that the fix for this problem (missing images and icons) will appear in the near future. In the meantime please use the suggested workaround: use SAVE option instead of publish. If you need to export the theme please SAVE it and download theme folder from the hard drive or server manually. The export functions does PUBLISH before exporting the theme. Thank you, Olivia
philippe.pphantom
philippe.pphantom posted this 03 March 2018
Olivia your explanation is difficult to believe; the solution I found is the one explained in the private ticket which you did not even have the courtesy to answer, not to mention the time you put in making this very insufficient public answer.
> Hi, > > Unfortunately we have temporary delays with Drupal fixes related to technical problems. We hope that the fix for this problem (missing images and icons) will appear in the near future. In the meantime please use the suggested workaround: use SAVE option instead of publish. If you need to export the theme please SAVE it and download theme folder from the hard drive or server manually. The export functions does PUBLISH before exporting the theme. > > Thank you, > Olivia > > Olivia your explanation is difficult to believe; the solution I found is the one explained in the private ticket which you did not even have the courtesy to answer, not to mention the time you put in making this very insufficient public answer.
