What is article: home ?
What is article: home ?What is article: home ?
What is article: home ?Hi,
Do you mean this title?
This is ab area of the content of the article named "Home".
Another question: When search is used the only thing left of my template is the logo, see attached
and not my design see http://dantick.dk/
I just want the search result to show up in article: home
And Another question the links in the Backward links how are they controlled / or changed ?
Kind regards
Alex
How to make this vertical menu work i has no "potion name" i moved it from the "footer"....
Where are my Themler files located ?
Your software is really difficult...
Alex
How to make this vertical menu work i has no "potion name" i moved it from the "footer".... Where are my Themler files located ? Your software is really difficult... AlexHi,
Themler theme includes a number of templates which are applied to different website pages automatically. Please check the following article:
http://answers.themler.io/articles/36343/how-to-work-with-templates-in-joomla-themes
The Home template can be used for website front page only. The search results pages uses Default template.
The backlinks can be removed under the Home tab >> Settings >> Product Backlinks.
Please check the following article on how to create Vertical Menu:
http://answers.themler.io/articles/6643/how-to-create-vertical-menus-in-joomla
It works with the native joomla menu modules only.
The problem with the vertical menu is not in Joomla. The problem is in Themler with the "potion name" there is no "potion name" in Themler
How do I make a vertical menu with the right "potion name" vmenu ??????????????
The problem with the vertical menu is not in Joomla. The problem is in Themler with the "potion name" there is no "potion name" in Themler How do I make a vertical menu with the right "potion name" vmenu ??????????????How to insert a vertical menu from the Themler "insert" menu there are only options for "horizontal" and "top menu" ???????????????????????????????????????????????????????????????????????????????????????
How to insert a vertical menu from the Themler "insert" menu there are only options for "horizontal" and "top menu" ???????????????????????????????????????????????????????????????????????????????????????Are there any good instructions videos somewhere ?
Are there any good instructions videos somewhere ?Hi,
To add the vertical menu, you need to follow the steps.
In Themler add the Module Position control and there you can set the module position name. Then inside Joomla add the menu module inside the position with the name you have chosen in Themler. Then using the instructions from the post above add the vmenu
suffix in the module settings so it will become the vertical menu.
You cannot add the vertical menu control from Themler, there is no such control. You should add a menu from Joomla and then in Themler you will see that menu with the vertical menu styles. Then it will become the selectable control and you will be able to style vertical menu as you wish.
