ampersand use in button
d.vangelder
d.vangelder posted this 14 March 2018
I want to use an ampersand in a button: A&R
How can this be done?
Hi, I want to use an ampersand in a button: A&R How can this be done?
Support Team posted this 14 March 2018
Unfortunately you cannot insert special characters into the button names.
Hi, Unfortunately you cannot insert special characters into the button names. Sincerely, Hella
ancimer.anze
ancimer.anze posted this 20 July 2018
When it will be available?
Support Team posted this 24 July 2018
In general, special characters are restricted in all Themler input fields on the ribbon (except code fields) to avoid problems inside Themler core. This is quite complex task which cannot be easily fixed unfortunately.
Hi, In general, special characters are restricted in all Themler input fields on the ribbon (except code fields) to avoid problems inside Themler core. This is quite complex task which cannot be easily fixed unfortunately. Thank you, Olivia
Vitaliy WD
Vitaliy WD posted this 24 July 2018
Hi.
You can try follow solution: On tab Insert you can choose More and then HTML control. In this control click on Edit HTML and paste this code:
<a href="#"><button>A&amp;R</button></a>
replace # by your link and &amp; by other character if needed.
> Hi, > > I want to use an ampersand in a button: A&R > How can this be done? Hi. You can try follow solution: On tab **Insert** you can choose **More** and then **HTML** control. In this control click on **Edit HTML** and paste this code: <a href="#"><button>A&amp;R</button></a> replace `#` by your link and `&amp;` by other character if needed.
Abbas Khan
Abbas Khan posted this 17 February 2026
Consistency is another reason why a good fantasy name matters so much. Many experienced players keep the same team name for multiple seasons because it becomes part of their identity within their gaming circles. Friends begin to recognize the lamar jackson fantasy names instantly. Rivals remember past matchups connected to it. This long-term familiarity builds tradition and loyalty.
Consistency is another reason why a good fantasy name matters so much. Many experienced players keep the same team name for multiple seasons because it becomes part of their identity within their gaming circles. Friends begin to recognize the **[lamar jackson fantasy names][1]** instantly. Rivals remember past matchups connected to it. This long-term familiarity builds tradition and loyalty. [1]: https://profantasynames.com/lamar-jackson-fantasy-names/
