being able to copy settings from one theme to another
being able to copy settings from one theme to anotherHi,
What exact settings do you mean? The code from the Sittings tab in the property window or the template styles? If you are talking about the template styles, simply use one theme as the starting point for the next website.
i just re did it but i had two different templates already built.. i created a table with elements and wanted for another template i made without having to re due it. seems to me it would be a great feature to be able to copy and past from one template to another after they are made for modifications.
thanks
i just re did it but i had two different templates already built.. i created a table with elements and wanted for another template i made without having to re due it. seems to me it would be a great feature to be able to copy and past from one template to another after they are made for modifications. thanksHi jbmcclain, you can always " save as " the theme, and than you can edit the new saved theme and it will retain your edits.... this works great for me....
