Hello, I have a specific Joomla extension that seems to trigger the Themler template message of a Bootstrap loading mulitple times (or whatever it says).
The extension developer says his extension uses Joomla's Bootstrap files. Where does Themler get them from? Or how does this work?
Can you explain the process more?
Hello, I have a specific Joomla extension that seems to trigger the Themler template message of a Bootstrap loading mulitple times (or whatever it says). The extension developer says his extension uses Joomla's Bootstrap files. Where does Themler get them from? Or how does this work? Can you explain the process more? Thanks
