javascript into themler
David Hale
David Hale posted this 27 July 2015
How to paste javascript into themler?
If external javascript libraries can be placed into themler
How to paste javascript into themler? If external javascript libraries can be placed into themler
6 Comments
Stagger Lee posted this 27 July 2015
In Settings under Javascript option.
shaulhadar
shaulhadar posted this 27 July 2015
Hi Erik, if you need to put external javascript libraries in themler you can do it only with the CDN version of them.
just put there reference in the "Additional HTML" area in the settings tab, and than add whatever you need straight inside themler :)
Hi Erik, if you need to put external javascript libraries in themler you can do it only with the CDN version of them. just put there reference in the "Additional HTML" area in the settings tab, and than add whatever you need straight inside themler :)
David Hale
Is Solution
ok thanks
ok thanks
peterkovacssoft
peterkovacssoft posted this 16 November 2015
Hi!
javascript detail that I can cut out the page, or if you need to refer to it in additional html to me? eg if you like to put on the page what do I do after the procedure.
http://tympanus.net/Tutorials/AnimatedMenuIcon/
Hi! javascript detail that I can cut out the page, or if you need to refer to it in additional html to me? eg if you like to put on the page what do I do after the procedure. http://tympanus.net/Tutorials/AnimatedMenuIcon/
emailrobind
emailrobind posted this 17 December 2016
if you add javascript to html it breaks the theme in mine -
The issue may be the code. Have you tested it with any other theme?
Hi, The issue may be the code. Have you tested it with any other theme? Sincerely, Hella
