YouTube Video without sound
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 25 May 2018
Since version 66 on Google Chrome videos with sound are no longer automatically played. Even videos without sound are detected by Chrome as a video with sound and not played.
If I now embed a YouTube video via HTML, the video starts, but plays only once and then stops. The Loopfunction only works with a playlist.
Therefore my urgent request that you get in a new version of the Themler the opportunity to integrate videos without sound and turn off the sound.
I think that's pretty important.
Thank you and kind regards from Germany,
Thorsten Schulz
Hello Since version 66 on Google Chrome videos with sound are no longer automatically played. Even videos without sound are detected by Chrome as a video with sound and not played. If I now embed a YouTube video via HTML, the video starts, but plays only once and then stops. The Loopfunction only works with a playlist. Therefore my urgent request that you get in a new version of the Themler the opportunity to integrate videos without sound and turn off the sound. I think that's pretty important. Thank you and kind regards from Germany, Thorsten Schulz [Werbeagentur Schulz-Design][1] [1]: https://www.schulzdesign.info
Support Team posted this 25 May 2018
Usually when you add the video embed code you can insert the parameter to disable sound. I'm not sure that we could create special option for that in Themler.
Hi, Usually when you add the video embed code you can insert the parameter to disable sound. I'm not sure that we could create special option for that in Themler. Sincerely, Hella
Yes of course,
but with no Loop.
I need this function.
Please add them to next update.
Thank you very much.
Yes of course, but with no Loop. I need this function. Please add them to next update. Thank you very much.
OK, we'll consider your suggestion.
Hi, OK, we'll consider your suggestion. Sincerely, Hella
thank you very much.
Thorsten
Hello, thank you very much. Sincerely, Thorsten [Werbeagentur Schulz-Design][1] [1]: http://www.schulzdesign.info
jondel2019
jondel2019 posted this 26 May 2019
Thanks for the solution ! Also you may share your large/restricted youtube files through keep2share site which you may refer by creating your keep2share account through keep2share premium
Thanks for the solution ! Also you may share your large/restricted youtube files through keep2share site which you may refer by creating your keep2share account through [keep2share premium][1] [1]: https://free-account.net/keep2share-premium/
zackki13597
zackki13597 posted this 2 weeks ago
You can access it directly on the youtube app. Or download video audio as ringtone here:tonos de llamada iphone
You can access it directly on the youtube app. Or download video audio as ringtone here:[tonos de llamada iphone][1] [1]: https://tonosdellamadacanciones.com/category/tonos-de-llamada-iphone/
jobssfair1
jobssfair1 posted this 6 days ago
you can insert the parameter to disable sound when you embed youtube Video, IFFCO Just Check You can fix it easily
you can insert the parameter to disable sound when you embed youtube Video, [IFFCO][1] Just Check You can fix it easily [1]: https://latestform.in/iffco-graduate-engineer-apprentice-online-form/
