How to stop mobile menu closing automatically when scrolling down the web page?
corcwebsite
corcwebsite posted this 28 May 2018
Dear Support,
When a user opens a mobile menu and expands on click, as soon as they start to scroll down the web page, the menu closes automatically which means they cannot select the menu options that reside at the bottom list.
This issue does not happen in a live preview mode, but only happens once the template is saved in Themler and viewed live from a mobile or tablet device.
Please provide a solution, have spent days on this and not found any fix...
The solution I require is the mobile menu will remain expanded, until the user clicks on the mobile menu icon to close, otherwise for people who have a long menu list, it's impossible to scroll down the page enough to select the menu items at the bottom of the list before the menu closes again...
Dear Support, When a user opens a mobile menu and expands on click, as soon as they start to scroll down the web page, the menu closes automatically which means they cannot select the menu options that reside at the bottom list. This issue does not happen in a live preview mode, but only happens once the template is saved in Themler and viewed live from a mobile or tablet device. Please provide a solution, have spent days on this and not found any fix... The solution I require is the mobile menu will remain expanded, until the user clicks on the mobile menu icon to close, otherwise for people who have a long menu list, it's impossible to scroll down the page enough to select the menu items at the bottom of the list before the menu closes again...
12 Comments
Support Team posted this 28 May 2018
Please provide a link to the site so we could see the issue. And also point on what menu items to click to see it.
Hi, Please provide a link to the site so we could see the issue. And also point on what menu items to click to see it. Sincerely, Hella
corcwebsite
corcwebsite posted this 29 May 2018
I gave up trying to fix the issue and have re-configured the mobile menu to a slide menu instead.
The slide menu however is not entirely fault free, when viewing from a smart phone (google on android) OR using a tablet (Firefox on android ver. 7) I see the following behavior:
  • List item
When the mobile menu slides across, as soon as I click on the menu icon to close, the top header remains pushed across to the right hand side, I have to refresh the page for the header to re-position correctly again.
This mostly happens once I have started scrolling down a web page, but depending on which device I am using, it also happens when positioned at the top of the web page.
This never seems to happen when viewing the website from a desktop computer but only on browsers on hand held devices.
Web link http://oxfordrowingclub.org.uk/
Thank you.
Hello, I gave up trying to fix the issue and have re-configured the mobile menu to a slide menu instead. The slide menu however is not entirely fault free, when viewing from a smart phone (google on android) OR using a tablet (Firefox on android ver. 7) I see the following behavior: - List item When the mobile menu slides across, as soon as I click on the menu icon to close, the top header remains pushed across to the right hand side, I have to refresh the page for the header to re-position correctly again. This mostly happens once I have started scrolling down a web page, but depending on which device I am using, it also happens when positioned at the top of the web page. This never seems to happen when viewing the website from a desktop computer but only on browsers on hand held devices. Web link http://oxfordrowingclub.org.uk/ Thank you.
Support Team posted this 29 May 2018
I've tested your website on my side in Chrome on Android but failed to reproduce the reported issue with Slide menu on my side. I've tried on scroll and on the top of the page. When the page scrolled the menu does not push the header because sticky header has fixed position and cannot be moved by the menu.
Could you please provide a few screenshots that demonstrate the issue?
Hi, I've tested your website on my side in Chrome on Android but failed to reproduce the reported issue with Slide menu on my side. I've tried on scroll and on the top of the page. When the page scrolled the menu does not push the header because sticky header has fixed position and cannot be moved by the menu. Could you please provide a few screenshots that demonstrate the issue? Thank you, Olivia
corcwebsite
Smart phone screenshot shows a small gap to the LHS where the header hasn't moved back to its original position after closing the mobile menu.
Tablet display the same issue but a much larger gap can be seen to the LHS
You might need to experiment with scrolling down the page a little and then repeat the test.
The fact that this happens on two different devices (and browsers) leads me to think there is an issue somewhere within the theme.
I can upload the theme via private message if required. Thanks
Hello, Smart phone screenshot shows a small gap to the LHS where the header hasn't moved back to its original position after closing the mobile menu. Tablet display the same issue but a much larger gap can be seen to the LHS You might need to experiment with scrolling down the page a little and then repeat the test. The fact that this happens on two different devices (and browsers) leads me to think there is an issue somewhere within the theme. I can upload the theme via private message if required. Thanks
Support Team posted this 30 May 2018
Thank you for the screenshots. I've asked our developers to check this issue.
We'll let you know when we receive any news from them.
Hi, Thank you for the screenshots. I've asked our developers to check this issue. We'll let you know when we receive any news from them. Thank you, Olivia
walksba.b.y
walksba.b.y posted this 14 May 2025
One of the primary benefits of GSMNeo FRP Bypass is its ability to restore access to smartphones locked by Google’s Factory Reset Protection (FRP). FRP is a security feature introduced by Google to protect user data in case a phone is lost or stolen. However, legitimate users often find themselves locked out of their own devices after a factory reset , especially if they forget their Google credentials. GSMNeo FRP Bypass provides a solution for such situations, enabling users to regain access to their devices without needing to recall old account information.
One of the primary benefits of [GSMNeo FRP Bypass][1] is its ability to restore access to smartphones locked by Google’s Factory Reset Protection (FRP). FRP is a security feature introduced by Google to protect user data in case a phone is lost or stolen. However, legitimate users often find themselves locked out of their own devices after a factory reset , especially if they forget their Google credentials. GSMNeo FRP Bypass provides a solution for such situations, enabling users to regain access to their devices without needing to recall old account information. [1]: https://gsmneofrp.website/
apkhura.com
apkhura.com posted this 11 June 2025
This is a really helpful tip for improving mobile user experience! Keeping the menu open while scrolling can make navigation so much smoother, especially on content-rich sites. It reminds me how important little details are for a good user journey, something even free APK download sites like APKHura.com need to consider for their visitors.
This is a really helpful tip for improving mobile user experience! Keeping the menu open while scrolling can make navigation so much smoother, especially on content-rich sites. It reminds me how important little details are for a good user journey, something even free APK download sites like [APKHura.com][1] need to consider for their visitors. [1]: https://apkhura.com/
gsmneofrpmx
gsmneofrpmx posted this 30 June 2025
I think GSMNEO is one the best free app for bypassing such products easily that cause issue while using.
I think [GSMNEO][1] is one the best free app for bypassing such products easily that cause issue while using. [1]: https://gsmneofrp.com.mx/
henryashford663
henryashford663 posted this 07 July 2025
thanks for sharing this thread.
eja.ge.r.m
eja.ge.r.m posted this 15 November 2025
It sounds like your mobile menu issue can be frustrating, much like trying to access rewards in pakistani teen patti games to download free earning games when a game glitch interrupts play check website here. Just as users want uninterrupted gameplay in free earning games, your mobile menu should remain fully accessible until intentionally closed.
It sounds like your mobile menu issue can be frustrating, much like trying to access rewards in pakistani teen patti games to download free earning games when a game glitch interrupts play [check website here][1]. Just as users want uninterrupted gameplay in free earning games, your mobile menu should remain fully accessible until intentionally closed. [1]: https://pakistaniteenpatti.com/
freddieleo425
freddieleo425 posted this 16 November 2025
I’ve been a phone technician for 8+ years and honestly… GSMNEO FRP is the single best thing that happened to the repair scene in 2025-2026.
It removes Google FRP lock in literally 60–90 seconds on Android 14 & 15 devices (tested this week on Galaxy A55 5G, Xiaomi 14T Pro, Redmi Note 14 Pro+, Moto Edge 50 Ultra, Realme 13 Pro+… all worked perfectly with the November 2025 security patch).
100 % web-based → no PC, no OTG cable, no drivers
Zero risk of tripping Knox or wiping user data
No tokens, no credits, no shady downloads
Completely FREE and updated weekly
If you ever get stuck on the “Verify your account” screen after a factory reset, just go here
I’ve been a phone technician for 8+ years and honestly… GSMNEO FRP is the single best thing that happened to the repair scene in 2025-2026. It removes Google FRP lock in literally 60–90 seconds on Android 14 & 15 devices (tested this week on Galaxy A55 5G, Xiaomi 14T Pro, Redmi Note 14 Pro+, Moto Edge 50 Ultra, Realme 13 Pro+… all worked perfectly with the November 2025 security patch). 100 % web-based → no PC, no OTG cable, no drivers Zero risk of tripping Knox or wiping user data No tokens, no credits, no shady downloads Completely FREE and updated weekly If you ever get stuck on the “Verify your account” screen after a factory reset, just [go here][1] [1]: https://thegsmneofrp.com.mx/
oliverharry728
oliverharry728 posted this 30 December 2025
This usually happens because the theme or template is set to auto-close the mobile menu on scroll (often for UX reasons), or because a JavaScript event is being triggered when the page scrolls. Since it only occurs after publishing (not in preview), it’s very likely tied to Themler’s generated JS/CSS.
Here are a few practical ways to fix or work around it (similar structured fixes are often shared on clear technical resource sites like https://deltaexecutorsa.com/
  1. Disable “close on scroll” behavior (if available)
Some Themler templates include a setting like:
Close menu on click / scroll
Auto-collapse menu
Check:
Menu settings
Header / Navigation settings
Mobile behavior options
If you find an option related to auto-closing or collapsing, disable it.
  1. Override the JavaScript behavior
The menu is probably closing because of a scroll event listener. You can override it by removing or blocking that behavior.
Add this custom JS (if Themler allows custom scripts):
window.onscroll = function () {
// Disable auto menu close on scroll
return false;
Or, more safely, target the menu specifically:
document.addEventListener('scroll', function (e) {
e.stopPropagation();
}, true);
  1. Force the mobile menu to stay open with CSS
Sometimes the menu is being set to display: none or collapsed via CSS on scroll.
Try adding custom CSS:
@media (max-width: 768px) {
.navbar-collapse {
display: block !important;
height: auto !important;
overflow-y: auto !important;
max-height: 80vh;
This also enables scrolling inside the menu instead of the page.
  1. Enable internal scrolling for long menus (recommended)
Instead of scrolling the page, make the menu itself scrollable:
.navbar-collapse {
max-height: 75vh;
overflow-y: auto;
This prevents the page scroll event from firing and closing the menu.
  1. Check for “sticky header” conflicts
If your header is fixed or sticky, it can conflict with scroll events on mobile.
Try:
Disabling sticky header on mobile
Or setting a higher z-index for the menu
.navbar {
z-index: 9999;
This usually happens because the theme or template is set to auto-close the mobile menu on scroll (often for UX reasons), or because a JavaScript event is being triggered when the page scrolls. Since it only occurs after publishing (not in preview), it’s very likely tied to Themler’s generated JS/CSS. Here are a few practical ways to fix or work around it (similar structured fixes are often shared on clear technical resource sites like https://deltaexecutorsa.com/ ): 1. Disable “close on scroll” behavior (if available) Some Themler templates include a setting like: Close menu on click / scroll Auto-collapse menu Check: Menu settings Header / Navigation settings Mobile behavior options If you find an option related to auto-closing or collapsing, disable it. 2. Override the JavaScript behavior The menu is probably closing because of a scroll event listener. You can override it by removing or blocking that behavior. Add this custom JS (if Themler allows custom scripts): window.onscroll = function () { // Disable auto menu close on scroll return false; }; Or, more safely, target the menu specifically: document.addEventListener('scroll', function (e) { e.stopPropagation(); }, true); 3. Force the mobile menu to stay open with CSS Sometimes the menu is being set to display: none or collapsed via CSS on scroll. Try adding custom CSS: @media (max-width: 768px) { .navbar-collapse { display: block !important; height: auto !important; overflow-y: auto !important; max-height: 80vh; } } This also enables scrolling inside the menu instead of the page. 4. Enable internal scrolling for long menus (recommended) Instead of scrolling the page, make the menu itself scrollable: @media (max-width: 768px) { .navbar-collapse { max-height: 75vh; overflow-y: auto; } } This prevents the page scroll event from firing and closing the menu. 5. Check for “sticky header” conflicts If your header is fixed or sticky, it can conflict with scroll events on mobile. Try: Disabling sticky header on mobile Or setting a higher z-index for the menu .navbar { z-index: 9999; }
