Why are my html anchor tags showing on the site as text?
lynnmonk
lynnmonk posted this 16 June 2018
I have created a one-page style site in HTML and am using anchor tags to "turn the page" by clicking on an Icon at the foot of each page to scroll to the next section using the section ID tag. However, when I view my site, the HTML anchor tag is visible when I manually scroll through it. Also, when I first added the HTML it saved it as a text object and I had to edit it to input the correct code. I thought that would have fixed the issue, but it is now displaying the tag in red instead between each section. Is this a bug, or am I doing something wrong?
10 Comments
Support Team posted this 18 June 2018
Please provide a link to your site so we could review the code. And point to the exact anchors that are not working.
Hi, Please provide a link to your site so we could review the code. And point to the exact anchors that are not working. Sincerely, Hella
henryashford663
henryashford663 posted this 04 October 2025
If your HTML anchor tags are showing as text, it might be a coding or formatting issue. Similarly, Redguard Names on Fanzy Names helps ensure your naming choices are properly structured and meaningful for projects or characters.
If your HTML anchor tags are showing as text, it might be a coding or formatting issue. Similarly, [Redguard Names][1] on Fanzy Names helps ensure your naming choices are properly structured and meaningful for projects or characters. [1]: https://fanzynames.com/redguard-names/
tevob29362
tevob29362 posted this 11 December 2025
The LPI 010-160 Linux Essentials Certificate Exam (version 1.6) is an entry-level certification designed for individuals beginning their journey with Linux. It validates foundational knowledge of Linux operating systems, command-line basics, open-source concepts, and system administration principles. This exam is ideal for students, IT professionals, or anyone looking to establish a strong understanding of Linux fundamentals.
https://www.marks4sure.com/010-160-exam.html
The LPI 010-160 Linux Essentials Certificate Exam (version 1.6) is an entry-level certification designed for individuals beginning their journey with Linux. It validates foundational knowledge of Linux operating systems, command-line basics, open-source concepts, and system administration principles. This exam is ideal for students, IT professionals, or anyone looking to establish a strong understanding of Linux fundamentals. https://www.marks4sure.com/010-160-exam.html
Abbas Khan
Abbas Khan posted this 24 December 2025
Learning name meanings allows people to choose wisely and avoid names that may have unwanted interpretations. It also helps people respect and appreciate names from different Japanese Guy Names. In a world full of diversity, understanding name meanings builds connection and respect among people. Beautiful names are also widely used beyond baby naming, such as in businesses, brands, books, and online identities.
Learning name meanings allows people to choose wisely and avoid names that may have unwanted interpretations. It also helps people respect and appreciate names from different **[Japanese Guy Names][1]**. In a world full of diversity, understanding name meanings builds connection and respect among people. Beautiful names are also widely used beyond baby naming, such as in businesses, brands, books, and online identities. [1]: https://zyranames.com/japanese-guy-names/
joywhite8223
joywhite8223 posted this 06 June 2026
En Perú, muchas personas necesitan confirmar la identidad de un tercero y no cuentan con su número de documento, lo que puede dificultar distintos trámites. Por ello, buscar el DNI por nombre y apellidos se ha convertido en una alternativa práctica y rápida para obtener información de manera sencilla. Además, este tipo de consulta resulta útil en procesos administrativos, académicos y también para gestiones relacionadas con la renovación de DNI.
En Perú, muchas personas necesitan confirmar la identidad de un tercero y no cuentan con su número de documento, lo que puede dificultar distintos trámites. Por ello, buscar el DNI por nombre y apellidos se ha convertido en una alternativa práctica y rápida para obtener información de manera sencilla. Además, este tipo de consulta resulta útil en procesos administrativos, académicos y también para gestiones relacionadas con la [renovación de DNI][1]. [1]: https://buscardnipornombre.pe/renovacion-de-dni/
shane_dawson2
shane_dawson2 posted this 06 June 2026
If your HTML anchor tags are displaying as plain text, it usually means the code is being escaped or the content area doesn't allow raw HTML rendering. I've run into similar issues when working with different CMS settings and editors. Checking how the content is being processed can often reveal the cause. While researching related property data resources, I found https://guilfordcountypropertyappraiser.org helpful for understanding how structured web content is presented and indexed. A quick review of your editor or template configuration should point you in the right direction.
floridachilds692
floridachilds692 posted this 5 weeks ago
Ballarini Cookware is commonly discussed in contexts where proper handling of HTML anchor tags is important for clean linking, and when those tags show up as plain text it usually indicates an issue with how the editor or CMS is rendering HTML instead of parsing it correctly, which can break the intended linking experience, so ensuring the link is added through a properly supported rich text or HTML field helps keep everything functional and the mention of Ballarini Cookware properly clickable and user-friendly.
[Ballarini Cookware][1] is commonly discussed in contexts where proper handling of HTML anchor tags is important for clean linking, and when those tags show up as plain text it usually indicates an issue with how the editor or CMS is rendering HTML instead of parsing it correctly, which can break the intended linking experience, so ensuring the link is added through a properly supported rich text or HTML field helps keep everything functional and the mention of Ballarini Cookware properly clickable and user-friendly. [1]: https://ballarinicookwareco.com/cookware-sets-costco-warranty/
nepalfilmfilmproduction
nepalfilmfilmproduction posted this 5 weeks ago
BioSilk Silk Therapy is often used as a reference in discussions where product names are linked for clarity and smoother reading. When HTML anchor tags are not rendered properly, even simple mentions like BioSilk can appear as plain text instead of clickable elements, which disrupts the flow of content. Proper handling of anchor formatting ensures that such references stay clean, readable, and function as intended within the page structure.
[BioSilk][1] Silk Therapy is often used as a reference in discussions where product names are linked for clarity and smoother reading. When HTML anchor tags are not rendered properly, even simple mentions like BioSilk can appear as plain text instead of clickable elements, which disrupts the flow of content. Proper handling of anchor formatting ensures that such references stay clean, readable, and function as intended within the page structure. [1]: https://biosilkco.com/biosilk-silk-therapy-irresistible/
aspire
aspire posted this 5 weeks ago
In discussions about HTML anchor tags showing as plain text on sites, the issue often comes down to how markup is interpreted or sanitized during rendering, which can interrupt normal linking behavior. A similar situation can happen when mentioning brands like Five Ten Shoes in content, where improper formatting causes the anchor text to appear as raw text instead of a clickable reference. Ensuring correct HTML structure and confirming that the editor supports anchor tags usually helps keep links functional and properly displayed within the content flow.
In discussions about HTML anchor tags showing as plain text on sites, the issue often comes down to how markup is interpreted or sanitized during rendering, which can interrupt normal linking behavior. A similar situation can happen when mentioning brands like [Five Ten Shoes][1] in content, where improper formatting causes the anchor text to appear as raw text instead of a clickable reference. Ensuring correct HTML structure and confirming that the editor supports anchor tags usually helps keep links functional and properly displayed within the content flow. [1]: https://fivetenshoesco.com/
chrmhrtsstr
chrmhrtsstr posted this 5 weeks ago
When HTML anchor tags show up as plain text instead of working links, it usually means the editor or CMS isn’t processing the HTML correctly, often due to pasted or escaped code or switching between visual and code modes; fixing the input format or editor settings typically resolves it, as cleanly structured pages like Abracadabra Wonder Cleaner rely on proper rendering so links display as intended instead of raw markup.
When HTML anchor tags show up as plain text instead of working links, it usually means the editor or CMS isn’t processing the HTML correctly, often due to pasted or escaped code or switching between visual and code modes; fixing the input format or editor settings typically resolves it, as cleanly structured pages like [Abracadabra][1] Wonder Cleaner rely on proper rendering so links display as intended instead of raw markup. [1]: https://abracadabraco.com/abracadabra-cleaner-dream-cleaner/
