Issues with woocommerce
lina3vt
lina3vt posted this 19 June 2018
Hi. I'm working with woocommerce but I get this message in the backend:
Your theme (Florist) contains non-updated copies of some WooCommerce template files. These files need to be modified to be compatible with the current version of WooCommerce. You can see what files have been affected on the system's status page. In case of doubt, consult with the author of the topic.
How do I fix this? Is this fixed if I update my themler? Thanks for your help
Hi. I'm working with woocommerce but I get this message in the backend: Your theme (Florist) contains non-updated copies of some WooCommerce template files. These files need to be modified to be compatible with the current version of WooCommerce. You can see what files have been affected on the system's status page. In case of doubt, consult with the author of the topic. How do I fix this? Is this fixed if I update my themler? Thanks for your help
Support Team posted this 19 June 2018
What Themler and Woocommerce versions are you using?
If you're using an old Themler theme we recommend to update it if you want to remove this message. But it should not affect general theme functionality.
Hi, What Themler and Woocommerce versions are you using? If you're using an old Themler theme we recommend to update it if you want to remove this message. But it should not affect general theme functionality. Thank you, Olivia
Abbas Khan
Abbas Khan posted this 17 May 2025
They are trained to diagnose problems quickly and repair them safely bosch washing machine repair dubai. A good appliance repair company offers fast service, fair pricing, and long-term solutions. In most cases, hiring a reliable expert is cheaper and safer than buying a new machine.
---------- They are trained to diagnose problems quickly and repair them safely **[bosch washing machine repair dubai][1]**. A good appliance repair company offers fast service, fair pricing, and long-term solutions. In most cases, hiring a reliable expert is cheaper and safer than buying a new machine. [1]: https://toptechappliancerepairs.ae/services/washing-machine-repair-dubai/
mary58wilson
mary58wilson posted this 13 November 2025
The WooCommerce warning indicates your Florist theme contains outdated custom copies of WooCommerce template files, which causes compatibility issues; the primary fix is to update the Florist theme to the latest version released by its developer (or the E-ZPass New Jersey version re-exported via Themler, if applicable), which incorporates the necessary changes for the current WooCommerce version, but if no update is available, you must manually check the WooCommerce $\rightarrow$ Status $\rightarrow$ Templates list and either delete or merge the outdated template files in your theme's folder.
The WooCommerce warning indicates your **Florist theme** contains outdated custom copies of WooCommerce template files, which causes compatibility issues; the primary fix is to **update the Florist theme** to the latest version released by its developer (or the [E-ZPass New Jersey][1] version re-exported via Themler, if applicable), which incorporates the necessary changes for the current WooCommerce version, but if no update is available, you must manually check the **WooCommerce $\rightarrow$ Status $\rightarrow$ Templates** list and either delete or merge the outdated template files in your theme's folder. [1]: https://www.ezpassn-j.com
