W3C Validation
Sumit Ojha
Sumit Ojha posted this 30 June 2018
We recently make a website by using themler and wordpress. Here is website: http://www.cloudninetherapy.com.au/
Happy with the end result but the website is not W3C Validated. Please help to fix the issue.
thanks
Hello We recently make a website by using themler and wordpress. Here is website: http://www.cloudninetherapy.com.au/ Happy with the end result but the website is not W3C Validated. Please help to fix the issue. thanks
Vitaliy WD
Vitaliy WD posted this 30 June 2018
If you need clean code with latest rules and standards by W3C, Google Insights etc. then you need to write your own code and control it, not to build with any of web builders and code generators. This is IMHO.
Now you can check all the errors and correct the code of Themler and 3rd party scriptst and plugins integrated and installed on your CMS.
If you need clean code with latest rules and standards by W3C, Google Insights etc. then you need to write your own code and control it, not to build with any of web builders and code generators. This is IMHO. Now you can check all the errors and correct the code of Themler and 3rd party scriptst and plugins integrated and installed on your CMS.
Support Team posted this 02 July 2018
I see only one error in the report from your site and it is related to the | sign in the Google Fonts URL, but that is how Google produces the code and we do not intend to change it. All the other warnings are not critical and may be ignored.
Hi, I see only one error in the report from your site and it is related to the `|` sign in the Google Fonts URL, but that is how Google produces the code and we do not intend to change it. All the other warnings are not critical and may be ignored. Sincerely, Hella
