Social media live feeds
deborah9
deborah9 posted this 06 July 2018
Good afternoon,
I want to add a Facebook and Twitter feed to my themes (wordpress). I know how to do it in wordpress using shortcakes, but when I add the short code to the theme, it says "Facebook feed not available", or something similar.
Can you please tell me if there is a specific wordpress plugin I need to use to be compatible with Themler.
Many thanks
Deborah
Good afternoon, I want to add a Facebook and Twitter feed to my themes (wordpress). I know how to do it in wordpress using shortcakes, but when I add the short code to the theme, it says "Facebook feed not available", or something similar. Can you please tell me if there is a specific wordpress plugin I need to use to be compatible with Themler. Many thanks Deborah
Support Team posted this 06 July 2018
Please let us know exactly what plugin you're using for this and where you're trying to insert FB feed. We'll test this plugin on our side.
Hi, Please let us know exactly what plugin you're using for this and where you're trying to insert FB feed. We'll test this plugin on our side. Thank you, Olivia
deborah9
Hi Olivia - the Facebook plug-in that i'm trying to use is https://wordpress.org/plugins/facebook-feed/
I am quite new to Themler so I'm maybe doing something wrong? I am adding a container then inserting the 'short code' from the insert [more] menu. Is this the right way to do it?
Many thanks
Deborah
Hi Olivia - the Facebook plug-in that i'm trying to use is https://wordpress.org/plugins/facebook-feed/ I am quite new to Themler so I'm maybe doing something wrong? I am adding a container then inserting the 'short code' from the insert [more] menu. Is this the right way to do it? Many thanks Deborah
Support Team posted this 09 July 2018
I've installed this plugin on my side and tested it with default WP theme (2017). It displays:
Cannot Display Feed
Pls check if the Facebook page exists or not.
if a enter shortcode into the WP page content.
I tried a few FB feeds. Did you test this plugin on the website you're working at this time with 2017 theme?
Hi, I've installed this plugin on my side and tested it with default WP theme (2017). It displays: `Cannot Display Feed Pls check if the Facebook page exists or not.` if a enter shortcode into the WP page content. I tried a few FB feeds. Did you test this plugin on the website you're working at this time with 2017 theme? Thank you, Olivia
