want to add a picture slider under menu and other other items in header
newgenisus
newgenisus posted this 03 August 2015
Good day,
I am wanting to place a slider in the header full size and place the menu, search bar with social media icons over the top. Been playing around the with the software but not sure if i am missing something simple?? When i add any of these or text it will only add it too one slide in the slider not all. If this cant be done, can you modify the software so its possible to say have a 00 slide that can be a blanket for all slides or just some of them?
Dave.
Good day, I am wanting to place a slider in the header full size and place the menu, search bar with social media icons over the top. Been playing around the with the software but not sure if i am missing something simple?? When i add any of these or text it will only add it too one slide in the slider not all. If this cant be done, can you modify the software so its possible to say have a 00 slide that can be a blanket for all slides or just some of them? Thanks, Dave.
Stagger Lee posted this 03 August 2015
I vote for it because it reduces unnecessary duplicate code.
Support Team posted this 04 August 2015
Hello guys,
the slider is made especially to allow use different design on each slide. You may copy necessary controls easy. However it's good idea to have an ability to create identical slides or share elements between slides. I'll add the suggestion to our wish list.
Hello guys, the slider is made especially to allow use different design on each slide. You may copy necessary controls easy. However it's good idea to have an ability to create identical slides or share elements between slides. I'll add the suggestion to our wish list. regards, Aileen
Just a follow up: the Duplicate Slide option may be a kind of workaround now:
You can create a first slide with number of basic color, text, image, etc. then copy it.
It does not reduce the amount of code, but helps to build slider faster.
Just a follow up: the Duplicate Slide option may be a kind of workaround now: !DuplicateSlide.png! You can create a first slide with number of basic color, text, image, etc. then copy it. It does not reduce the amount of code, but helps to build slider faster. Regards, Aileen
cybster
cybster posted this 29 October 2015
Hi, I think what he is trying to do is what I did in Artisteer (see the attachment). The HMenu sits over the top of the slider. This is a Joomla 3 Template.
The reason I found this post is because I cannot replicate this layout with Themler. Artisteer cannot export, with Themler support, for Joomla yet.
I have been able to get the menu to sit over the slider, but it moves as the slide moves. Any ideas?
Hi, I think what he is trying to do is what I did in Artisteer (see the attachment). The HMenu sits over the top of the slider. This is a Joomla 3 Template. The reason I found this post is because I cannot replicate this layout with Themler. Artisteer cannot export, with Themler support, for Joomla yet. I **have** been able to get the menu to sit over the slider, but it moves as the slide moves. Any ideas?
Support Team posted this 29 October 2015
Hello Steve,
you may export from Artisteer to Themler Joomla. To do it use the latest Artisteer version
http://files4.artisteer.com/Artisteer.4.3.0.60858.exe
Hello Steve, you may export from Artisteer to Themler Joomla. To do it use the latest Artisteer version http://files4.artisteer.com/Artisteer.4.3.0.60858.exe regards, Aileen
