The content of the "standard" Page in joomla template disappears
luca.anchini
luca.anchini posted this 12 July 2018
meanwhile I was testing some themler function, I deleted the "HTML" component under the "Page" template.
Now, into the website, if I go in a page that use the "Page" template, couse has got no meta data, it will show blank.
Which component I need to insert into template to show the joomla content for the "page" template?
Hi, meanwhile I was testing some themler function, I deleted the "HTML" component under the "Page" template. Now, into the website, if I go in a page that use the "Page" template, couse has got no meta data, it will show blank. Which component I need to insert into template to show the joomla content for the "page" template? Thank you
Vitaliy WD
Vitaliy WD posted this 12 July 2018
Hi.
Try this: go to Insert tab and click on Content & Sidebars, there enable CMS Content option.
Hi. Try this: go to **Insert** tab and click on **Content & Sidebars**, there enable **CMS Content** option.
luca.anchini
Hi.
Yes, I solved with this! :)
> Hi. > > Try this: go to **Insert** tab and click on **Content & Sidebars**, there enable **CMS Content** option. Yes, I solved with this! :) Thank you
