How do you enter in a button?
m-s
m-s posted this 16 July 2018
How do you enter in a button? When I press the enter key when editing a button - nothing happens. I need this to move the letter "i" to the second line. In the annex screen.
http://dolinaraby.pl/
How do you enter in a button? When I press the enter key when editing a button - nothing happens. I need this to move the letter "i" to the second line. In the annex screen. http://dolinaraby.pl/
10 Comments
Vitaliy WD
Vitaliy WD posted this 16 July 2018
This is not about Themler, but about some basics of informatics. Shift + Enter will help you.
m-s
I tried - unfortunately it does not work
Vitaliy WD
Strange that this not work on your side, I'm just now tried this in Themler and all ok.
Please clarify in which button you try to do this.
And try to set White-space: normal; in Arrange. And word-wrap: break-word; .
Strange that this not work on your side, I'm just now tried this in Themler and all ok. Please clarify in which button you try to do this. And try to set `White-space: normal;` in **Arrange**. And `word-wrap: break-word;` .
m-s
In each I try to the left - and it does not work
http://dolinaraby.pl/ In each I try to the left - and it does not work
Vitaliy WD
Vitaliy WD posted this 17 July 2018
Well, I think that there need access to admin panel and Themler editor.
You can try to create private topic with this data and maybe official support help you.
Well, I think that there need access to admin panel and Themler editor. You can try to create private topic with this data and maybe official support help you.
Support Team posted this 17 July 2018
Hello Marek,
When you click on the section of that button, you should be able to switch to HTML view, for example:
Clicking on that would open window where you can edit the text directly in html. Paste
tag between the words where you need a break.
Themler support
Hello Marek, When you click on the section of that button, you should be able to switch to HTML view, for example: !html.png! Clicking on that would open window where you can edit the text directly in html. Paste <br> tag between the words where you need a break. Thank you, Gina Themler support
m-s
m-s posted this 17 July 2018
But I need to edit the button
Vitaliy WD
Vitaliy WD posted this 18 July 2018
DId you tried to press Shift + Enter exactly inside button text (not in Text fileld)?
Check this video: https://streamable.com/dfdrq
DId you tried to press Shift + Enter exactly inside button text (not in Text fileld)? Check this video: https://streamable.com/dfdrq
Support Team posted this 18 July 2018
When I add bкeaks in my button, I can see
tags in the text field. You can try adding such a tag as well where you need a break. If this doesn't work, please, create a private topic and provide access to your site.
Themler support
When I add bкeaks in my button, I can see <br> tags in the text field. You can try adding such a tag as well where you need a break. If this doesn't work, please, create a private topic and provide access to your site. Thank you Gina Themler support
Vitaliy WD
This will not help as this &lt;br&gt; will be converted to simple text 'br'. So only Shift + Enter exactly inside button text (not in Text field) will help.
> You can try adding such a tag as well where you need a break. This will not help as this `&lt;br&gt;` will be converted to simple text 'br'. So only Shift + Enter exactly inside button text (not in Text field) will help.
