Set Language in Google Maps
info1142
info1142 posted this 18 July 2018
Hi there,
I use the Google Maps Plugin in Themler for a website in german language. However the frontend shows "View larger map" in english language. Looking into thre source code of that page I see src="//maps.google.com/maps?output=embed&q=Sonneneck, Riefensbeek-Kamschlacken&t=m&hl=English", so english seems to be hardcoded for Google Maps.
Is there any way I can set german language for that plugin? In Joomla itself german is default language for the site.
Thanx, Jörg
Hi there, I use the Google Maps Plugin in Themler for a website in german language. However the frontend shows "View larger map" in english language. Looking into thre source code of that page I see src="//maps.google.com/maps?output=embed&q=Sonneneck, Riefensbeek-Kamschlacken&t=m&hl=English", so english seems to be hardcoded for Google Maps. Is there any way I can set german language for that plugin? In Joomla itself german is default language for the site. Thanx, Jörg
Support Team posted this 25 July 2018
Sorry for the delay. If you're using Themler Google Map control please check the UI Language settings of the control on the ribbon. You should be able to change the language of the map ui controls with this option.
Hi, Sorry for the delay. If you're using Themler Google Map control please check the **UI Language** settings of the control on the ribbon. You should be able to change the language of the map ui controls with this option. Thank you, Olivia
info1142
info1142 posted this 03 August 2018
Thank you!
Thank you!
Support Team posted this 03 August 2018
