How to apply sub templates to pages manually ??
khaledwhisper
khaledwhisper posted this 01 September 2014
How to apply sub templates to pages manually in joomla 3.3 ?? ..
like apply home template to another menu link ??
How to apply sub templates to pages manually in joomla 3.3 ?? .. like apply home template to another menu link ??
Support Team posted this 01 September 2014
The page templates are applied automatically. Unfortunately you can apply Home page template to some other page.
Joomla does not have "page templates" feature naively.
The Page Class suffix is a little different thing. So it can't be used in this case.
Hello The page templates are applied automatically. Unfortunately you can apply Home page template to some other page. Joomla does not have "page templates" feature naively. The Page Class suffix is a little different thing. So it can't be used in this case. Thank you, Olivia
khaledwhisper
i know that the Class suffix is use for modules .. but in my case i start template in home page and when i install it it gives me 3 different styles based on random choice for pages .. i want to know how to make single template and use it for all pages !! .. And some thing else when i don't use any modules to left position it still take the same place although it's empty unlike artisteer which column disappear and the content expand at the full place
Regards..
Dido
i know that the Class suffix is use for modules .. but in my case i start template in home page and when i install it it gives me 3 different styles based on random choice for pages .. i want to know how to make single template and use it for all pages !! .. And some thing else when i don't use any modules to left position it still take the same place although it's empty unlike artisteer which column disappear and the content expand at the full place Regards.. Dido
Support Team posted this 02 September 2014
Unfortunately Themler template always contains page templates.
Home template - is applied to the joomla front page only.
Post template - is applied to the Simgle Article with metadata enabled (date, author, print, etc)
Page template - is applied to the Single Article metadata disabled (all metadata should be disabled or enabled only those icons that were added to this page template).
Blog template - is applied to the Category Blog or Featured Articles.
Default template - is applied to all other pages.
To duplicate controls to the other page templates you can use Paste as Link option.
Unfortunately you can't disable using page templates at this time.
Themler is based on bootstrap framework. This framework always reserves space for the column even if it's empty. This is feature of bootstrap.
Artisteer is using its own framework and different page structure.
Hello Unfortunately Themler template always contains page templates. *Home template* - is applied to the joomla front page only. *Post template* - is applied to the Simgle Article with metadata **enabled** (date, author, print, etc) *Page template* - is applied to the Single Article metadata **disabled** (all metadata should be disabled or enabled only those icons that were added to this page template). *Blog template* - is applied to the Category Blog or Featured Articles. *Default template* - is applied to all other pages. To duplicate controls to the other page templates you can use *Paste as Link* option. Unfortunately you can't disable using page templates at this time. > And some thing else when i don't use any modules to left position it still take the same place although it's empty Themler is based on bootstrap framework. This framework always reserves space for the column even if it's empty. This is feature of bootstrap. Artisteer is using its own framework and different page structure. Please let us know if you have any other questions. Thank you, Olivia
