post image float right or left chosen by Joomla article parameter
jnskst
jnskst posted this 03 August 2015
Hi, I want to have my postimage flexible float left or right, chosen by Joomla article parameter.
I can do it fixed in themler but how it's possible like in original templates?
regards
Jens
Hi, I want to have my postimage flexible float left or right, chosen by Joomla article parameter. I can do it fixed in themler but how it's possible like in original templates? regards Jens
19 Comments
Stagger Lee posted this 03 August 2015
Go to Image "More options" and chose display:block or inline-block for images in Articles.
jnskst
and remove the float?
It is empty by default. But if it is activated set options to none.
jnskst
Sorry, but it do not work. here is the link. the first article has picture float left by joomla and the second float right by joomla
http://hifi-profis.j-koester.de/index.php?option=com_content&view=category&layout=blog&id=10&Itemid=162
Sorry, but it do not work. here is the link. the first article has picture float left by joomla and the second float right by joomla http://hifi-profis.j-koester.de/index.php?option=com_content&view=category&layout=blog&id=10&Itemid=162
I dont work in Joomla. It is a blog list and all images have same named classes and divs.
How do you align those images ? Inside Joomla Readmore part in editor ?
I dont work in Joomla. It is a blog list and all images have same named classes and divs. How do you align those images ? Inside Joomla Readmore part in editor ?
jnskst
jnskst posted this 04 August 2015
Its controlled by joomla option for each article within the article option. please see the attachment.
I need to place the image left, right, left, right and so on.
Its controlled by joomla option for each article within the article option. please see the attachment. I need to place the image left, right, left, right and so on.
Support Team posted this 09 September 2015
Hello Jens,
I'm very sorry for delay in response.
The settings from the Article Options >> Images from the Joomla admin back end are not used by Themler. It's behavior by design.
Please try using the :nth-child() selector to detect the odd and even row and specify different float:
http://www.w3schools.com/cssref/sel_nth-child.asp
Hello Jens, I'm very sorry for delay in response. The settings from the Article Options >> Images from the Joomla admin back end are not used by Themler. It's behavior by design. Please try using the `:nth-child()` selector to detect the odd and even row and specify different float: http://www.w3schools.com/cssref/sel_nth-child.asp regards, Aileen
Scorpion Computers & Software
Scorpion Computers & Software posted this 15 October 2016
Oke, it has been more than a year since the last response. Still this feature is not fixed in Themler. I also want to use this functionality and i am sure i'm not the only one.
Joomla normaly just adds a bootstrap class like "pull-right" in the surrounding DIV
Can you please add this functionality?
Here's a piece of code from the original component for content
<?php $imgfloat = (empty($images->float_fulltext)) ? $params->get('float_fulltext') : $images->float_fulltext; ?>
<div class="pull-<?php echo htmlspecialchars($imgfloat); ?> item-image"> <img
<?php if ($images->image_fulltext_caption):
    echo 'class="caption"' . ' title="' . htmlspecialchars($images->image_fulltext_caption) . '"';
endif; ?>
Oke, it has been more than a year since the last response. Still this feature is not fixed in Themler. I also want to use this functionality and i am sure i'm not the only one. Joomla normaly just adds a bootstrap class like "pull-right" in the surrounding DIV Can you please add this functionality? Here's a piece of code from the original component for content <?php $imgfloat = (empty($images->float_fulltext)) ? $params->get('float_fulltext') : $images->float_fulltext; ?> <div class="pull-<?php echo htmlspecialchars($imgfloat); ?> item-image"> <img <?php if ($images->image_fulltext_caption): echo 'class="caption"' . ' title="' . htmlspecialchars($images->image_fulltext_caption) . '"'; endif; ?>
Support Team posted this 18 October 2016
Hello Edwin,
the issues related to Joomla articles options was discussed year ago and it was decided not to inherit these settings in Themler theme.
So the solution is to use custom CSS as recommended before.
Hello Edwin, the issues related to Joomla articles options was discussed year ago and it was decided not to inherit these settings in Themler theme. So the solution is to use custom CSS as recommended before. regards, Aileen
Scorpion Computers & Software posted this 01 November 2016
I'm very sorry but i don't think that is acceptable. It is not that difficult for your developers to implement adding a class form a Joomla attribute. Custom CSS still needs to know what the websites manager has chosen for the image. I am talking about a simgle article view.
Scorpion Computers & Software posted this 04 November 2016
I have created a solution myself and i want to share this with you
I have also asked Themler to implement it in the next version
In the file html/com_content/article/deafult_template.php
After every line that has the code
<?php ob_start(); ?>
Place the following piece of codeafter that (6 times in my current template)
<?php
// Added by Scorpion Computers & Software
// Adds class for pulling the article image left or right
$myparams  = $this->item->params;
$images  = json_decode($this->item->images);
$imgfloat = (empty($images->float_fulltext)) ? $myparams->get('float_fulltext') : $images->float_fulltext;
$imgfloafclass = 'pull-' . $imgfloat;
$params['image-float'] = $imgfloafclass;
// End of added by Scorpion Computers & Software
The go to the files include/article_2.php to include/article_7.php and look for a line that has the class="bd-postimage in it. In the class parameter add the following code
 <?php echo $data['image-float'];?>
As an example the line should look something like this
<div class=" bd-postimage-4 bd-no-margins <?php echo $data['image-float'];?>">
I have created a solution myself and i want to share this with you I have also asked Themler to implement it in the next version In the file html/com_content/article/deafult_template.php After every line that has the code <?php ob_start(); ?> Place the following piece of codeafter that (6 times in my current template) <?php // Added by Scorpion Computers & Software // Adds class for pulling the article image left or right $myparams = $this->item->params; $images = json_decode($this->item->images); $imgfloat = (empty($images->float_fulltext)) ? $myparams->get('float_fulltext') : $images->float_fulltext; $imgfloafclass = 'pull-' . $imgfloat; $params['image-float'] = $imgfloafclass; // End of added by Scorpion Computers & Software ?> The go to the files include/article_2.php to include/article_7.php and look for a line that has the **class="bd-postimage** in it. In the class parameter add the following code <?php echo $data['image-float'];?> As an example the line should look something like this <div class=" bd-postimage-4 bd-no-margins <?php echo $data['image-float'];?>">
Bayern
Bayern posted this 06 November 2016
For me this is superfluous
i use the JCE Editor and i can place an image where ever i want
For me this is superfluous i use the JCE Editor and i can place an image where ever i want
d.vangelder
d.vangelder posted this 09 November 2016
Hi Scorpion Computers & Software,
I implemented your solution but without any effect.
In the article_4, article_5, article_6, and article_7 files I could not find the div class.
Hope you can point me to a sollution.
Danny
Hi Scorpion Computers & Software, I implemented your solution but without any effect. In the article_4, article_5, article_6, and article_7 files I could not find the div class. Hope you can point me to a sollution. Danny
Bayern
Bayern posted this 09 November 2016
there is no div
You add a picture using the JCE, place it on the left, center or right
there is no div You add a picture using the JCE, place it on the left, center or right !1.png!
d.vangelder
d.vangelder posted this 11 November 2016
Hello support team,
You mentioned that this can be done by using nth-child.
Do you have a manual how to do so in themler?
kind Regards,
Danny
Hello support team, You mentioned that this can be done by using nth-child. Do you have a manual how to do so in themler? kind Regards, Danny
Support Team posted this 15 November 2016
Hello Danny,
the
http://www.w3schools.com/cssref/tryit.asp?filename=trycss3_nth-child_odd_even
provides good CSS example.
If you need help with incorporating it exactly into your theme please provide link to your blog page
Hello Danny, the http://www.w3schools.com/cssref/tryit.asp?filename=trycss3_nth-child_odd_even provides good CSS example. If you need help with incorporating it exactly into your theme please provide link to your blog page regards, Aileen
tekgearco098
tekgearco098 posted this 21 April 2026
https://open.firstory.me/story/cmmwhh3vo01cw01zkh7b5gbsu
https://referrallist.com/profile/smith-wilson/
https://sabaylok.com/blogs/69815/Tek-Gear-Activewear-for-Everyday-Comfort-and-Performance
https://ulystar.in/blogs/94901/Upgrade-Your-Fitness-Style-with-Tek-Gear-Activewear
https://www.cake.me/me/tekk-gear
https://www.ganjingworld.com/news/1idp70t871772gElu1fb34z0i16j1c/move-better-with-stylish-tek-gear-activewear-essentials
http://www.golocalezservices.com/shipping-delivery/tek-gear
https://www.provenexpert.com/smith28/?mode=preview
https://www.qurito.io/question/1751469263425/logo-clothing-wearable-branding-that-speaks-volumes/
https://www.rumorcircle.com/blogs/255296/Stay-Active-and-Comfortable-with-Tek-Gear-Activewear
https://www.scenario.press/blogs/323341/Experience-Comfort-and-Performance-with-Tek-Gear-Activewear
https://www.usafreeclassifieds.org/classifieds/business-opportunities_2/general/tek-gear-clothing_i971410
https://eo-college.org/members/tekgearco/
https://castbox.fm/channel/Women%E2%80%99s-Clothing-Store-in-Barbados-id5474041?country=us
https://expressy.co.in/experience-ultimate-performance-with-tek-gear-activewear-essentials/
https://inkbunny.net/tekgearco
https://plazoo.in.net/article/move-with-ease-in-tek-gear-active-pants-for-every-activity
https://projectcasting.com/professional/jacks-william
https://www.workingholidayjobs.com.au/forums/users/tekg12/
http://jobs.emiogp.com/author/tekgo1/
https://animead.com/user/profile/51728
https://blogswirl.in.net/article/tek-gear-pants-built-for-flexibility-and-everyday-wear
https://edostate.com/thread/62560
https://freeglobalclassifiedads.com/business-opportunities_2/general/tek-gear-clothing_i3260651
https://www.articledude.com/classifieds/for-sale/tek-gear-clothing_i151967
https://www.leadclub.net/classifieds/for-sale/tek-gear-clothing_i105234
https://www.mysportsgo.com/profile/131729
https://bizidex.com/en/tek-gear-brand-fashion-shop-908105
https://www.chimty.com/listing/washington/airway-heights-147/Other-2/tek-gear-brand
https://www.gooalsocial.com/topics/view/650
https://kisanlink.com/forums/discussion/general-discussion/red-hood-jackets
https://tutorialslink.com/member/Tekkgear/95152
https://www.aviacionargentina.net/user/tekgearco
https://my.lawschoolnumbers.com/tekkgear
https://www.reviewadda.com/asks/how-do-i-express-my-personality-through-streetwear-styles-by-combining-different-brands-and-clothing-items
https://www.soshified.com/forums/user/664507-tekgearco/
https://triberr.com/tekgearco
https://www.divephotoguide.com/user/tekgear1
https://www.freelistingindia.in/listings/tek-gear-clothing-brand
https://www.hopp.bio/tekk-gear
https://zumvu.com/tekgearco/
https://joinentre.com/profile/tekgearco
https://app.wedonthavetime.org/profile/tekk_gear
https://justpaste.me/8Ddw7
https://participacion.puertodelrosario.org/profiles/tekkgear1/activity
https://dapp.orvium.io/profile/tekk-gear
https://forum.liquidbounce.net/user/tekgearco09
https://tekgearclothing.mobirisesite.com/
https://findaspring.org/members/tekkgear/profile/
https://www.campfirewriting.com/user/tekgearc
https://www.checkli.com/tekgearco
https://pastelink.net/u31igqgt
https://www.ewebdiscussion.com/threads/leadinglady-in-shop-lingerie-shapewear-activewear-online.287688/
https://hearthis.at/tekk-gear/tek-gear-co-podcast/oUW/
https://www.myminifactory.com/users/tekkgear
https://www.tkaraoke.com/forums/profile/tekgearco098gmail-com/
https://gravatar.com/kryptoniteunique5c6c1015af
https://www.techrepublic.com/forums/discussions/will-ai-replace-white-collar-workers-or-just-reshape-their-roles/#post-4354539
https://solo.to/tekgearco
https://worldvectorlogo.com/profile/tekk-gear
https://www.speedrun.com/users/tekgearco
https://www.spreaker.com/episode/tek-gear-co-podcast--71119090
https://my.usaflag.org/members/tekgear2/profile/
https://tapas.io/tekgearco098
https://leasedadspace.com/members/tekgearco2/
https://www.pinterest.com/tekgearco098/_profile/
https://www.hulkshare.com/tekgearco1
https://www.babelcube.com/user/mike-jackson
https://www.futurelearn.com/profiles/23121099
https://www.anime-planet.com/users/mikewilson2
https://unsplash.com/@tekgearco1
https://speakerdeck.com/tekgearco1
https://hub.docker.com/u/tekgearco1?_gl=1ioye42_gcl_au*MTUwMDcxMTc3Mi4xNzc1NzQyNTQz*_ga*MTMwNzkzMjE3NS4xNzc1NzQyNTQy*_ga_XJWPQMJYHQ*czE3NzU3NDI1NDEkbzEkZzEkdDE3NzU3NDI1OTckajQkbDAkaDA.
https://www.facer.io/u/Tekgearco
https://hosted.weblate.org/user/mikewilson2/
https://www.inkitt.com/tekgearbrand
https://mercadodinamico.com.br/author/tekgo1/
https://kuula.co/profile/kl54966
https://www.komoot.com/user/5654036467281
https://wakelet.com/wake/LkuNc7aaN7hJZem6L4ALd
https://www.tripadvisor.com/Profile/tekkg2026
https://peatix.com/user/29343281/view
https://decidim.santcugat.cat/profiles/tekk_gear/activity
https://open.firstory.me/story/cmmwhh3vo01cw01zkh7b5gbsu https://referrallist.com/profile/smith-wilson/ https://sabaylok.com/blogs/69815/Tek-Gear-Activewear-for-Everyday-Comfort-and-Performance https://ulystar.in/blogs/94901/Upgrade-Your-Fitness-Style-with-Tek-Gear-Activewear https://www.cake.me/me/tekk-gear https://www.ganjingworld.com/news/1idp70t871772gElu1fb34z0i16j1c/move-better-with-stylish-tek-gear-activewear-essentials http://www.golocalezservices.com/shipping-delivery/tek-gear https://www.provenexpert.com/smith28/?mode=preview https://www.qurito.io/question/1751469263425/logo-clothing-wearable-branding-that-speaks-volumes/ https://www.rumorcircle.com/blogs/255296/Stay-Active-and-Comfortable-with-Tek-Gear-Activewear https://www.scenario.press/blogs/323341/Experience-Comfort-and-Performance-with-Tek-Gear-Activewear https://www.usafreeclassifieds.org/classifieds/business-opportunities_2/general/tek-gear-clothing_i971410 https://eo-college.org/members/tekgearco/ https://castbox.fm/channel/Women%E2%80%99s-Clothing-Store-in-Barbados-id5474041?country=us https://expressy.co.in/experience-ultimate-performance-with-tek-gear-activewear-essentials/ https://inkbunny.net/tekgearco https://plazoo.in.net/article/move-with-ease-in-tek-gear-active-pants-for-every-activity https://projectcasting.com/professional/jacks-william https://www.workingholidayjobs.com.au/forums/users/tekg12/ http://jobs.emiogp.com/author/tekgo1/ https://animead.com/user/profile/51728 https://blogswirl.in.net/article/tek-gear-pants-built-for-flexibility-and-everyday-wear https://edostate.com/thread/62560 https://freeglobalclassifiedads.com/business-opportunities_2/general/tek-gear-clothing_i3260651 https://www.articledude.com/classifieds/for-sale/tek-gear-clothing_i151967 https://www.leadclub.net/classifieds/for-sale/tek-gear-clothing_i105234 https://www.mysportsgo.com/profile/131729 https://bizidex.com/en/tek-gear-brand-fashion-shop-908105 https://www.chimty.com/listing/washington/airway-heights-147/Other-2/tek-gear-brand https://www.gooalsocial.com/topics/view/650 https://kisanlink.com/forums/discussion/general-discussion/red-hood-jackets https://tutorialslink.com/member/Tekkgear/95152 https://www.aviacionargentina.net/user/tekgearco https://my.lawschoolnumbers.com/tekkgear https://www.reviewadda.com/asks/how-do-i-express-my-personality-through-streetwear-styles-by-combining-different-brands-and-clothing-items https://www.soshified.com/forums/user/664507-tekgearco/ https://triberr.com/tekgearco https://www.divephotoguide.com/user/tekgear1 https://www.freelistingindia.in/listings/tek-gear-clothing-brand https://www.hopp.bio/tekk-gear https://zumvu.com/tekgearco/ https://joinentre.com/profile/tekgearco https://app.wedonthavetime.org/profile/tekk_gear https://justpaste.me/8Ddw7 https://participacion.puertodelrosario.org/profiles/tekkgear1/activity https://dapp.orvium.io/profile/tekk-gear https://forum.liquidbounce.net/user/tekgearco09 https://tekgearclothing.mobirisesite.com/ https://findaspring.org/members/tekkgear/profile/ https://www.campfirewriting.com/user/tekgearc https://www.checkli.com/tekgearco https://pastelink.net/u31igqgt https://www.ewebdiscussion.com/threads/leadinglady-in-shop-lingerie-shapewear-activewear-online.287688/ https://hearthis.at/tekk-gear/tek-gear-co-podcast/oUW/ https://www.myminifactory.com/users/tekkgear https://www.tkaraoke.com/forums/profile/tekgearco098gmail-com/ https://gravatar.com/kryptoniteunique5c6c1015af https://www.techrepublic.com/forums/discussions/will-ai-replace-white-collar-workers-or-just-reshape-their-roles/#post-4354539 https://solo.to/tekgearco https://worldvectorlogo.com/profile/tekk-gear https://www.speedrun.com/users/tekgearco https://www.spreaker.com/episode/tek-gear-co-podcast--71119090 https://my.usaflag.org/members/tekgear2/profile/ https://tapas.io/tekgearco098 https://leasedadspace.com/members/tekgearco2/ https://www.pinterest.com/tekgearco098/_profile/ https://www.hulkshare.com/tekgearco1 https://www.babelcube.com/user/mike-jackson https://www.futurelearn.com/profiles/23121099 https://www.anime-planet.com/users/mikewilson2 https://unsplash.com/@tekgearco1 https://speakerdeck.com/tekgearco1 https://hub.docker.com/u/tekgearco1?_gl=1*ioye42*_gcl_au*MTUwMDcxMTc3Mi4xNzc1NzQyNTQz*_ga*MTMwNzkzMjE3NS4xNzc1NzQyNTQy*_ga_XJWPQMJYHQ*czE3NzU3NDI1NDEkbzEkZzEkdDE3NzU3NDI1OTckajQkbDAkaDA. https://www.facer.io/u/Tekgearco https://hosted.weblate.org/user/mikewilson2/ https://www.inkitt.com/tekgearbrand https://mercadodinamico.com.br/author/tekgo1/ https://kuula.co/profile/kl54966 https://www.komoot.com/user/5654036467281 https://wakelet.com/wake/LkuNc7aaN7hJZem6L4ALd https://www.tripadvisor.com/Profile/tekkg2026 https://peatix.com/user/29343281/view https://decidim.santcugat.cat/profiles/tekk_gear/activity
tekgearco098
https://myanimelist.net/profile/tekgearco
https://devfolio.co/@tekgearco/readme-md
https://weboworld.com/listing/england/washington/Shopping-2/tek-gear-clothing-2
https://www.pubpub.org/user/smith-jackson
https://groups.google.com/g/tek-gear-clothing-brand
https://all4.vip/p/page/view-persons-profile?id=115554
https://linktr.ee/tekgearco
https://www.malaysialistings.com/listings/tek-gear-brand
https://www.daddycow.com/topics/view/9407
https://unbusinessnews.com/2026/03/03/upgrade-your-wardrobe-with-tek-gear-athletic-essentials-line-2026/
https://metaldevastationradio.com/tekgearcos
https://co-roma.openheritage.eu/profiles/_1363/activity
https://log.concept2.com/profile/2873188
https://openlibrary.org/people/tekk_gear
https://community.windy.com/user/tekk-gear
https://qiita.com/tekgearco098
https://issuu.com/tekgearco
https://steemit.com/tekgear/@fainamiller/stay-comfortable-and-active-with-tek-gear-performance-wear
https://huggingface.co/tekgearco098
https://www.walkscore.com/people/166326220219/walk-score-user
https://www.magcloud.com/user/tekgearr2
https://glass-sock-ae9.notion.site/Move-Freely-with-Comfortable-Tek-Gear-Activewear-Styles-3253535ab01c8080a372f2aff01a3c47?pvs=73
https://slides.com/d/GfLID2A/speaker/qbk9EpU
https://tekgearco.start.page/
https://leetcode.com/u/tekgearco098/
https://gitlab.com/tekgearco098
https://www.designspiration.com/tekgearco098/saves/
https://tekgearco.exposure.co/
https://community.intercom.com/apps-integrations-25/mcp-for-europe-14035?postid=37347#post37347
https://tekgearco.mypixieset.com/
https://www.instapaper.com/p/17551987
https://savee.com/tekgearco098/
https://webyourself.eu/blogs/1847034/Comfortable-Tek-Gear-Activewear-for-Everyday-Performance
https://www.proko.com/@tekk_gear/activity
https://experiment.com/users/jjackyjames
https://review.stylevore.com/tek-gear-brand/
https://review.gymbuddynow.com/tek-gear-brand/
https://fueler.io/tekgearco09
https://gitlab.aicrowd.com/tekk_gear
https://stocktwits.com/tekgearco
https://community.shopify.com/t/improving-navigation-in-my-shopify-store/592283/5
https://tekgear2.gumroad.com/?_gl=19cpznh_ga*NDAxNDYzODExLjE3NzM3NzQ1NzU.*_ga_6LJN6D94N6*czE3NzM3NzQ1NzQkbzEkZzEkdDE3NzM3NzQ2NjQkajQzJGwwJGgw
https://www.intensedebate.com/people/tekg2
https://doodleordie.com/profile/tekgearco
https://www.getlisteduae.com/listings/tek-gear-clothing-bran
https://land-book.com/tekk_gear_374132
https://pinshape.com/users/8929728-tekgearco09?tab=designs
https://www.freelistingaustralia.com/listings/tek-gear-brand
https://www.wantoask.com/user/tekgear
https://eilo.org/user/tekgearco
https://hypothes.is/users/tekgearco
https://www.yumpu.com/user/tekk.gear
https://comunitat.canodrom.barcelona/profiles/tekk_gear/activity?locale=en
https://www.freelistingusa.com/listings/tek-gear-brand
https://www.myfishingreport.com/blog-view.php?id=39328
https://www.whizolosophy.com/category/choices-decisions/article-essay/stay-comfortable-and-stylish-with-tek-gear-activewear-gear
https://workforgood.co.uk/businesses/tek-gear-brand
https://open.spotify.com/episode/2SFY4B6coha5wAndiqRLPk?si=QxVLvpiURZKuMqhap8cHqg
https://listen.hubhopper.com/episode/tek-gear-clothing-2026-podcast/32991150
https://dreevoo.com/profile.php?pid=1339184
https://soundcloud.com/tekk-gear/tek-gear-co-podcast
https://www.mixcloud.com/tekgearco/tek-gear-clothing-podcast-2026/
https://myanimelist.net/profile/tekgearco https://devfolio.co/@tekgearco/readme-md https://weboworld.com/listing/england/washington/Shopping-2/tek-gear-clothing-2 https://www.pubpub.org/user/smith-jackson https://groups.google.com/g/tek-gear-clothing-brand https://all4.vip/p/page/view-persons-profile?id=115554 https://linktr.ee/tekgearco https://www.malaysialistings.com/listings/tek-gear-brand https://www.daddycow.com/topics/view/9407 https://unbusinessnews.com/2026/03/03/upgrade-your-wardrobe-with-tek-gear-athletic-essentials-line-2026/ https://metaldevastationradio.com/tekgearcos https://co-roma.openheritage.eu/profiles/_1363/activity https://log.concept2.com/profile/2873188 https://openlibrary.org/people/tekk_gear https://community.windy.com/user/tekk-gear https://qiita.com/tekgearco098 https://issuu.com/tekgearco https://steemit.com/tekgear/@fainamiller/stay-comfortable-and-active-with-tek-gear-performance-wear https://huggingface.co/tekgearco098 https://www.walkscore.com/people/166326220219/walk-score-user https://www.magcloud.com/user/tekgearr2 https://glass-sock-ae9.notion.site/Move-Freely-with-Comfortable-Tek-Gear-Activewear-Styles-3253535ab01c8080a372f2aff01a3c47?pvs=73 https://slides.com/d/GfLID2A/speaker/qbk9EpU https://tekgearco.start.page/ https://leetcode.com/u/tekgearco098/ https://gitlab.com/tekgearco098 https://www.designspiration.com/tekgearco098/saves/ https://tekgearco.exposure.co/ https://community.intercom.com/apps-integrations-25/mcp-for-europe-14035?postid=37347#post37347 https://tekgearco.mypixieset.com/ https://www.instapaper.com/p/17551987 https://savee.com/tekgearco098/ https://webyourself.eu/blogs/1847034/Comfortable-Tek-Gear-Activewear-for-Everyday-Performance https://www.proko.com/@tekk_gear/activity https://experiment.com/users/jjackyjames https://review.stylevore.com/tek-gear-brand/ https://review.gymbuddynow.com/tek-gear-brand/ https://fueler.io/tekgearco09 https://gitlab.aicrowd.com/tekk_gear https://stocktwits.com/tekgearco https://community.shopify.com/t/improving-navigation-in-my-shopify-store/592283/5 https://tekgear2.gumroad.com/?_gl=1*9cpznh*_ga*NDAxNDYzODExLjE3NzM3NzQ1NzU.*_ga_6LJN6D94N6*czE3NzM3NzQ1NzQkbzEkZzEkdDE3NzM3NzQ2NjQkajQzJGwwJGgw https://www.intensedebate.com/people/tekg2 https://doodleordie.com/profile/tekgearco https://www.getlisteduae.com/listings/tek-gear-clothing-bran https://land-book.com/tekk_gear_374132 https://pinshape.com/users/8929728-tekgearco09?tab=designs https://www.freelistingaustralia.com/listings/tek-gear-brand https://www.wantoask.com/user/tekgear https://eilo.org/user/tekgearco https://hypothes.is/users/tekgearco https://www.yumpu.com/user/tekk.gear https://comunitat.canodrom.barcelona/profiles/tekk_gear/activity?locale=en https://www.freelistingusa.com/listings/tek-gear-brand https://www.myfishingreport.com/blog-view.php?id=39328 https://www.whizolosophy.com/category/choices-decisions/article-essay/stay-comfortable-and-stylish-with-tek-gear-activewear-gear https://workforgood.co.uk/businesses/tek-gear-brand https://open.spotify.com/episode/2SFY4B6coha5wAndiqRLPk?si=QxVLvpiURZKuMqhap8cHqg https://listen.hubhopper.com/episode/tek-gear-clothing-2026-podcast/32991150 https://dreevoo.com/profile.php?pid=1339184 https://soundcloud.com/tekk-gear/tek-gear-co-podcast https://www.mixcloud.com/tekgearco/tek-gear-clothing-podcast-2026/ https://open.firstory.me/story/cmmwhh3vo01cw01zkh7b5gbsu
tekskosong.xyz
tekskosong.xyz posted this 03 May 2026
Generator teks kosong online. Dapatkan teks kosong dengan mudah untuk semua keperluan Anda.
https://tekskosong.xyz/
Generator teks kosong online. Dapatkan teks kosong dengan mudah untuk semua keperluan Anda. https://tekskosong.xyz/
