I have a question about making mobile version of site. Is it possible to edit mobile version without changing anthing on computer version?
Themler does not create a separate mobile template. You can switch into the responsive modes and set the different colors, font sizes, positions and add specific controls using the Display on option to disable them on other responsive views.
How to switch it? When I click ''mobile'' in up-right corner it changes mobile and also computer version
How to switch it? When I click ''mobile'' in up-right corner it changes mobile and also computer versionHi,
When you are in any mode, you can right-click on any section to call the menu -> select More Options and there on the right panel you would see Display On options:
You can use this option to add sections with different styles (and content) for each view.
It is totally possible, on the contrary it doesn't matter. Both have different templates. Use the add section option and select your preferred styles.
It is totally possible, on the contrary it doesn't matter. Both have different templates. Use the add section option and select your preferred styles.To edit the mobile version of a website without affecting the desktop version, use a website Kohi speed test, which typically allows changes to trickle down from the desktop to mobile but not vice versa. For a real-time view and to make adjustments on your computer, use browser developer tools, which allow you to toggle device simulation and adjust specific mobile layouts without altering the desktop view in the browser.
To edit the mobile version of a website without affecting the desktop version, use a website [Kohi speed test][1], which typically allows changes to trickle down from the desktop to mobile but not vice versa. For a real-time view and to make adjustments on your computer, use browser developer tools, which allow you to toggle device simulation and adjust specific mobile layouts without altering the desktop view in the browser. [1]: https://cpsandtypingtest.com/kohi-click-test/To create or edit a mobile version of a website without altering the desktop version, use responsive design techniques like GB WhatsApp Download CSS media queries or website builder mobile editors. These tools allow for separate styling (hiding/resizing elements) for mobile, while keeping the desktop layout intact.
To create or edit a mobile version of a website without altering the desktop version, use responsive design techniques like [GB WhatsApp Download][1] CSS media queries or website builder mobile editors. These tools allow for separate styling (hiding/resizing elements) for mobile, while keeping the desktop layout intact. [1]: https://gbwhtapps.net/
