Hover Box in Home and Blog page
web.SSMB.pe
web.SSMB.pe posted this 03 August 2015
Hi. I remember that so weeks ago I could work with Hover Box by clicking in "Background" or "Hover" slide and working controls in the slide. But, now, when I try to do that, if I click, for example, in "Hover" slide, it shows me "Hover" slide but I can't work with the controls. If I try to do it, "Hover" slide disappear and "Background" slide appear, so I can't work with th position, for example. It's really hard to add a control in the "Hover" slide because the "Hover" slide disappear. How can I do to work with Hover Box properly?
Stagger Lee posted this 03 August 2015
It is really hard to add things in the two hover box states. For instance if I go to insert one global control from "Insert" tab "background" state is gone and cannot use it. Say for example I want to add CMS. Code conttrol, or something else.
Support Team posted this 04 August 2015
I confirm that it is difficult to locate controls inside HoverBox for some reason but it should be overcame in the next update.
However I cannot reproduce the issue described in the initial post: the Hover slide is substituted with Background slide. If possible could you provide several screenshots which cover your steps or short movie?
Hello, I confirm that it is difficult to locate controls inside HoverBox for some reason but it should be overcame in the next update. However I cannot reproduce the issue described in the initial post: the Hover slide is substituted with Background slide. If possible could you provide several screenshots which cover your steps or short movie? Regards, Aileen
web.SSMB.pe
web.SSMB.pe posted this 04 August 2015
Hi, Aileen. Well, you confirm that it's difficult to locate controls inside Hover Box. The problem is when I try to locate controls inside Background Slide because, when I try to locate it, the Hover Box appears.
I remember when, somes weeks ago, I clicked on "Hover" or on "Background" and I could work in this slide. I think the problem is that you changes the locate of the Hover Box controls. I mean, before, the Hover Box controls ("Background" and "Hover"), they was before all the post's controls, in the same window. Now, if I access to the Hover Box controls, the post's controls aren't in the same windows. So, when I return to the post's controls, the Hover Box window is closed.
Sorry for my bad english. I hope you can understand me.
Thanks.
Hi, Aileen. Well, you confirm that it's difficult to locate controls inside Hover Box. The problem is when I try to locate controls inside Background Slide because, when I try to locate it, the Hover Box appears. I remember when, somes weeks ago, I clicked on "Hover" or on "Background" and I could work in this slide. I think the problem is that you changes the locate of the Hover Box controls. I mean, before, the Hover Box controls ("Background" and "Hover"), they was before all the post's controls, in the same window. Now, if I access to the Hover Box controls, the post's controls aren't in the same windows. So, when I return to the post's controls, the Hover Box window is closed. Sorry for my bad english. I hope you can understand me. Thanks.
Support Team posted this 10 August 2015
Sorry for the delay.
Before adding a control inside HoverBox please click on it. Then it will be easier to add control on bg layer.
Hello Sorry for the delay. > The problem is when I try to locate controls inside Background Slide because, when I try to locate it, the Hover Box appears. Before adding a control inside HoverBox please **click on it**. Then it will be easier to add control on bg layer. Thank you, Olivia
