how do I add terms and conditions into the footer?
jackymoore10
jackymoore10 posted this 23 August 2018
SEE Screen shot.... how do I add this into my footer for the BLUE SCREEN SHOT, LIKE THE BLACK ONE, so it does NOT APPEAR IN THE main HORIZONTAL MENU?
THANKS.
SEE Screen shot.... how do I add this into my footer for the BLUE SCREEN SHOT, LIKE THE BLACK ONE, so it does NOT APPEAR IN THE main HORIZONTAL MENU? THANKS.
6 Comments
Support Team posted this 24 August 2018
Unfortunately, your questions is not quite clear to me.
Do you mean that you want to simply insert a link to some page into the Footer? What CMS are you using? Could you please explain the question in more details?
In general, you can add Text control with the desired link it Themler. Or this can be a CMS module.
Hi, Unfortunately, your questions is not quite clear to me. Do you mean that you want to simply insert a link to some page into the Footer? What CMS are you using? Could you please explain the question in more details? In general, you can add Text control with the desired link it Themler. Or this can be a CMS module. Thank you, Olivia
jackymoore10
jackymoore10 posted this 25 August 2018
I will try to explain a bit better, I want add a link to their privacy policy but I don't want to link it to the main menu.
I am using joomla.
I will try to explain a bit better, I want add a link to their privacy policy but I don't want to link it to the main menu. I am using joomla.
Support Team posted this 27 August 2018
Hello Jacky,
You can add any link to your footer using Text control. Click inside the footer (or on the plus icon in it) and insert Text either via menu tab on top and in the right-click mouse menu:
Once the text is added, you can change it and add any URL to it using this icon:
Hello Jacky, You can add any link to your footer using Text control. Click inside the footer (or on the plus icon in it) and insert Text either via menu tab on top and in the right-click mouse menu: !text-insert.png! Once the text is added, you can change it and add any URL to it using this icon: !make-link.png! Sincerely, Gina Themler Support
jackymoore10
jackymoore10 posted this 28 August 2018
I have the text already in the footer, but it needs to link to somewhere in the site.
Now I want to create the same as on the example shown here:
https://elegancesalon.co.uk - so this is the main page with the menu at the top.
and at the bottom there are links to privacy policy - I want to add my terms and conditions.
https://elegancesalon.co.uk/privacy-policy/
I have the text already in the footer, but it needs to link to somewhere in the site. Now I want to create the same as on the example shown here: https://elegancesalon.co.uk - so this is the main page with the menu at the top. and at the bottom there are links to privacy policy - I want to add my terms and conditions. https://elegancesalon.co.uk/privacy-policy/
jackymoore10
So I want to create a hidden article in a module.
Support Team posted this 28 August 2018
This site https://elegancesalon.co.uk has simple links to other pages on the site, added by same way as we described. If you need to do same, you just need to create a page (or article) and link the text in the footer to that way via right-click menu.
This site https://elegancesalon.co.uk has simple links to other pages on the site, added by same way as we described. If you need to do same, you just need to create a page (or article) and link the text in the footer to that way via right-click menu. Gina Themler Support
