Social icon's on mobile dont work
nocdevelop
nocdevelop posted this 01 September 2018
Social Icons controller does not work on mobile version of website.
nocdevelop
Is Solution
Solved issue.
Solved issue.
Barbora K.
Barbora K. posted this 02 September 2018
Hi, I have the same issue, how did you solve this? Thanks :-)
Support Team posted this 03 September 2018
Hi Barbora,
Please explain the exact issue with the social icons? The screen shot will be also helpful.
Hi Barbora, Please explain the exact issue with the social icons? The screen shot will be also helpful. Sincerely, Hella
Barbora K.
Barbora K. posted this 04 September 2018
Hi Hella, thanks :-) you can see it live:
klasikaplus.cz
  • rounded social icons to the left from search box. Works on desktop, on phone they are not clicable.
Originally I had those as a plain joomla position in themler and added via custom module with html, it didn't work (same way - worked on desktop, not clicable on phone), so I've tried to add it directly to themler as icons, as it actually also seemed to be much more elegant solution :-) but it didn't help.
Barbora
Hi Hella, thanks :-) you can see it live: klasikaplus.cz - rounded social icons to the left from search box. Works on desktop, on phone they are not clicable. Originally I had those as a plain joomla position in themler and added via custom module with html, it didn't work (same way - worked on desktop, not clicable on phone), so I've tried to add it directly to themler as icons, as it actually also seemed to be much more elegant solution :-) but it didn't help. Barbora
Support Team posted this 04 September 2018
Hello Barbora,
In mobile views the row with the search takes entire screewidth (even though the search input doesn't) and covers social icons. It is not visible for the site visitors but can be seen in the code. As a solution you can set hiegher z-index to the row with the icons in Themler: right-click on the container with the icons, select More Options and in the opened right panel set z-index to 99, for example. If you have any issues doing this, please, create private support ticket and provide us temporary access to the site.
Hello Barbora, In mobile views the row with the search takes entire screewidth (even though the search input doesn't) and covers social icons. It is not visible for the site visitors but can be seen in the code. As a solution you can set hiegher z-index to the row with the icons in Themler: right-click on the container with the icons, select More Options and in the opened right panel set z-index to 99, for example. If you have any issues doing this, please, create private support ticket and provide us temporary access to the site. Thank you, Gina Themler Support
