Can not import artisteer templates ???
einkauf4
einkauf4 posted this 04 August 2015
Hey guys,
we can not import artisteer templates... Why ???
Hey guys, we can not import artisteer templates... Why ???
39 Comments
langnetcb
langnetcb posted this 08 October 2015
What version of Artisteer is able to export files Themler? Where can
I find it?
The official version Artisteer of it can not do (See figure where to find export)
The latest official version Artisteer
http://www.artisteer.com/?p=downloads 4.3.0.60745
** > What version of Artisteer is able to export files Themler? Where can > I find it? ** The official version Artisteer of it can not do (See figure where to find export) The latest official version Artisteer http://www.artisteer.com/?p=downloads 4.3.0.60745
Support Team posted this 08 October 2015
1.the login/password for WP admin back end is
admin/admin
please try to log in with these credentials.
You may get the WP login form instead of opened theme if in WP admin back the non-Themler theme is activated.
Open WP admin back end, activate Themler theme and then try to open WP theme in Themler Desktop. It should be opened without asking you to log in to WP.
2.the latest Artisteer version which includes the Themler export option is
http://files4.artisteer.com/Artisteer.4.3.0.60858.exe
please feel free to download and install it.
Hello, 1.the login/password for WP admin back end is admin/admin please try to log in with these credentials. You may get the WP login form instead of opened theme if in WP admin back the non-Themler theme is activated. Open WP admin back end, activate Themler theme and then try to open WP theme in Themler Desktop. It should be opened without asking you to log in to WP. 2.the latest Artisteer version which includes the Themler export option is http://files4.artisteer.com/Artisteer.4.3.0.60858.exe please feel free to download and install it. regards, Aileen
langnetcb
Themler not
Themler not
Support Team posted this 09 October 2015
The screenshot does not show the URL. Looks like you're still trying to load Themler when Themler theme is not active.
Please try the following workaround:
  1. access this page in browser: http://127.0.0.1:12080/themler_407332135/wordpress/wp-admin
  2. You should see the regular WP login screen. Log in with admin/admin
  3. Go to Appearance >> Themes and activate Themler theme.
  4. Then load Themler in browser or start Themler Desktop.
Hi, The screenshot does not show the URL. Looks like you're still trying to load Themler when Themler theme is not active. Please try the following workaround: 1. access this page in browser: http://127.0.0.1:12080/themler_407332135/wordpress/wp-admin 2. You should see the regular WP login screen. Log in with admin/admin 3. Go to Appearance >> Themes and activate Themler theme. 4. Then load Themler in browser or start Themler Desktop. Please let us know the result. Thank you, Olivia
langnetcb
langnetcb posted this 09 October 2015
OK.
The first step was good.
But the message:
"Apologies, but the page you requested could not be found. Perhaps
searching will help."
What to do?
Lang
OK. The first step was good. But the message: > "Apologies, but the page you requested could not be found. Perhaps > searching will help." What to do? Thank you, Lang
Please check WP Settings >> Reading. What are the settings for the Front page? If the Front page is a static page please make sure that this page exists under the WP Pages.
Please check WP Settings >> Reading. What are the settings for the Front page? If the Front page is a static page please make sure that this page exists under the WP Pages. Thank you, Olivia
langnetcb
Thank you for your help.
I solved the problem installing Themler.
They even managed to import a file from Artisteer.
You can even edit the file.
Import But big mistakes. (See picture)
It is normal.
I'm making a mistake somewhere.
Lang
Thank you for your help. I solved the problem installing Themler. They even managed to import a file from Artisteer. You can even edit the file. Import But big mistakes. (See picture) It is normal. I'm making a mistake somewhere. Thank you, Lang
Themler does not include content editor now, but you can import the content from Artisteer template. Just use the Import Content option from the pop-up screen that appears when you import the theme in Themler.
Hi, Themler does not include content editor now, but you can import the content from Artisteer template. Just use the Import Content option from the pop-up screen that appears when you import the theme in Themler. Sincerely, Hella
langnetcb
Ok.
this can not.
I proceed according to the preview in the Annex.
Other offer to import appears.
Please help
thank you
Lang
Ok. this can not. I proceed according to the preview in the Annex. Other offer to import appears. Please help thank you Lang
it looks like you exported Artisteer theme without content. Please make sure that you enabled 'Include Content' option and re-export the theme:
Hello, it looks like you exported Artisteer theme without content. Please make sure that you enabled 'Include Content' option and re-export the theme: !ExportDialog.png! regards, Aileen
wolgamot
wolgamot posted this 14 November 2015
At the moment only Wordpress and joomla can be converted to themeler themes.
X5tuts
You mentioned for Wordpress and Joomla?
I tried the updated version of artisteer and used the themler export and it seemed to be for wordpress only. I primarily use Joomla and would like to know if there is a separate Artisteer download for exporting to Joomla?
j.wolgamot
> At the moment only Wordpress and joomla can be converted to themeler themes. > > Regards > > X5tuts You mentioned for Wordpress and Joomla? I tried the updated version of artisteer and used the themler export and it seemed to be for wordpress only. I primarily use Joomla and would like to know if there is a separate Artisteer download for exporting to Joomla? Thanks, j.wolgamot
Support Team posted this 16 November 2015
Simply enter your license key here and download the latest Artisteer version (I believe it's 4.3.0.60858 Win):
http://www.artisteer.com/?p=license_info
It has a possibility to export Joomla projects to Themler.
Ivan
Hi, Simply enter your license key here and download the latest Artisteer version (I believe it's 4.3.0.60858 Win): http://www.artisteer.com/?p=license_info It has a possibility to export Joomla projects to Themler. Thanks, Ivan
lovenino
lovenino posted this 20 November 2015
i get an error when i try to install Themler/Joomla template on my XAMPP local host.
I'm using latest Artisteer 4.3.0.60858,
i exported as "Template : Themler" + "CMS : Joomla" a zip file.
Then when i try to install it on Joomla 3.4.5 it fails showing this :
"JInstaller: :Install: File does not exist E:\xampp\htdocs\sitename\tmp\install_564f41eee7f76\fields"
Installation of templates exported as "Template : Joomla model" success without errors.
any suggestion ?
Hello, i get an error when i try to install Themler/Joomla template on my XAMPP local host. I'm using latest Artisteer 4.3.0.60858, i exported as "Template : Themler" + "CMS : Joomla" a zip file. Then when i try to install it on Joomla 3.4.5 it fails showing this : "JInstaller: :Install: File does not exist E:\xampp\htdocs\sitename\tmp\install_564f41eee7f76\fields" Installation of templates exported as "Template : Joomla model" success without errors. any suggestion ?
Support Team posted this 20 November 2015
lovenino,
Could you please create a new private topic and provide there your .artx project and the exported ,zip for investigation?
**lovenino**, Could you please create a new private topic and provide there your .artx project and the exported ,zip for investigation? Sincerely, Nettie, BillionDigital Team
lovenino
lovenino,
Just done
> **lovenino**, > > Could you please create a new private topic and provide there your .artx project and the exported ,zip for investigation? > > Sincerely, > Nettie, > BillionDigital Team > > Just done
sandy.spence
sandy.spence posted this 14 December 2015
How long will it be before we can expect to see the import facility for Joomla templates?
Support Team posted this 15 December 2015
Hi Sandy,
Could you please explain your issue in some more details.
You can export artx projects to Themler for Joomla with the latest Artisteer version.
Ivan
Hi Sandy, Could you please explain your issue in some more details. You can export artx projects to Themler for Joomla with the latest Artisteer version. Please let us know if you have any further questions. Thanks, Ivan
PHdJ
PHdJ posted this 25 February 2016
I also exported the theme from Artisteer, in the way it should to be able to import it in Themler.
But when running it in Themler, it seems that the theme is seen as html and one cannot edit it like with a native Themler theme?
I also exported the theme from Artisteer, in the way it should to be able to import it in Themler. But when running it in Themler, it seems that the theme is seen as html and one cannot edit it like with a native Themler theme?
Support Team posted this 01 March 2016
PHdJ ,
Could you please try exporting with this Artisteer version:
http://files3.artisteer.com/Artisteer.4.3.0.60902.exe
Let us know if there are any issues with it.
**PHdJ** , Could you please try exporting with this Artisteer version: http://files3.artisteer.com/Artisteer.4.3.0.60902.exe Let us know if there are any issues with it. Sincerely, Nettie, BillionDigital Team
