Use Themler desktop in Firefox
JGA
JGA posted this 04 September 2018
Hi All,
I installed the desktop version of Themler. At setup it says that it should work with Firefox an Chrome, however, when I double click the Themler icon it says it's missing the folder "AppData/Local/Themler/ChromeData".
So can I use Firefox to create / edit themes or do I have to have Chrome installed to do so? (and is the "works with chrome and Firefox" referring to when you use Themler on an online Wordpress website?).
And if i indeed can use Firefox with the desktop version, can you please explain how to get it working?
Thanks in advance.
Best Regards,
JGA
Hi All, I installed the desktop version of Themler. At setup it says that it should work with Firefox an Chrome, however, when I double click the Themler icon it says it's missing the folder "AppData/Local/Themler/ChromeData". So can I use Firefox to create / edit themes or do I have to have Chrome installed to do so? (and is the "works with chrome and Firefox" referring to when you use Themler on an online Wordpress website?). And if i indeed can use Firefox with the desktop version, can you please explain how to get it working? Thanks in advance. Best Regards, JGA
Support Team posted this 04 September 2018
Actually it should also work with FF, but we recommend to use Chrome as Themler was built on the webkit engine and it is optimized to be working with Chrome.
Try to reinstall FF and then install Themler again.
Hi, Actually it should also work with FF, but we recommend to use Chrome as Themler was built on the webkit engine and it is optimized to be working with Chrome. Try to reinstall FF and then install Themler again. Sincerely, Hella
JGA
Ok, here's what I ended up doing:
So apparently there were some leftovers from older versions of FF (39 and 54 I think), so I uninstalled those.
I also uninstalled Themler.
Then I used the FF setup to sort of reinstall it (so I didn't remove the latest version as it was up to date).
My bookmarks were still there, but I did have to reinstall the add-ons and reconfigure my settings again.
Finally I reinstalled Themler again, which then worked.
Bit of a hassle, but it works now.
Thanks.
Ok, here's what I ended up doing: So apparently there were some leftovers from older versions of FF (39 and 54 I think), so I uninstalled those. I also uninstalled Themler. Then I used the FF setup to sort of reinstall it (so I didn't remove the latest version as it was up to date). My bookmarks were still there, but I did have to reinstall the add-ons and reconfigure my settings again. Finally I reinstalled Themler again, which then worked. Bit of a hassle, but it works now. Thanks.
Thanks for letting us know. Please feel free to contact us if any questions appear in process.
Thanks for letting us know. Please feel free to contact us if any questions appear in process. Sincerely, Nettie
offrobloxapk
offrobloxapk posted this 27 February 2026
You can use Firefox with Themler, but sometimes it needs Chrome files to run properly, so reinstalling Chrome once may fix the folder issue. After that, Firefox should work fine for editing themes. Also, if you like trying new tools for games, you can check out the download Delta Roblox from deltaexecutor.com.br It's easy to use and many players find it helpful. Hopefully your Themler setup will be working smoothly soon.
You can use Firefox with Themler, but sometimes it needs Chrome files to run properly, so reinstalling Chrome once may fix the folder issue. After that, Firefox should work fine for editing themes. Also, if you like trying new tools for games, you can check out the download Delta Roblox from [deltaexecutor.com.br][1] It's easy to use and many players find it helpful. Hopefully your Themler setup will be working smoothly soon. [1]: https://deltaexecutor.com.br/
