Hello Everyone,
I ve just created a theme for joomla. I cannot create my own template because, automatically navigates to "Page Not Found" section. I cannot manually navigate to Home section.
Hello Everyone,
Please make sure there is a menu item marked as Home or Front page in Joomla admin. Let usknow if the issue persists.
I think this has nothing to do with joomla admin.
I've wached themler for joomla tutorial. It says "if the home template isn't available in themler please check the current side menu includes the joomla default menu item." I have no idea what that means. Is there any documentation related to this topic?
I think this has nothing to do with joomla admin. !Capture.PNG! I've wached themler for joomla tutorial. It says "if the home template isn't available in themler please check the current side menu includes the joomla default menu item." I have no idea what that means. Is there any documentation related to this topic?Last edited 05 September 2018 by ertankanter
That is exactly what I suggested to check, please try step-by-step:
1. Navigate to Joomla admin using Joomla icon in the top right corner.
2. Go to the Menus, select Menu and make sure that for some item the option "Use as website Front page" or "Use as default item" is enabled.
3. Refresh Content in Themler on the top right.
