shortcodes issue on php version over 7.0
souacz
souacz posted this 10 September 2018
Hi, I noticed the issue using shortcodes one_half, one_third etc. When the php version is set to 7.0 shortcodes work correct but on versions 7.1 and 7.2 the shortcodes do not arrange the columns and the column's contents are one under the other.
sample (php 7.0): http://marcintafelski.pl/ and http://marcintafelski.pl/kontakt
sample (php 7.2): http://kapita.pl/ and http://kapita.pl/kontakt
Hi, I noticed the issue using shortcodes one_half, one_third etc. When the php version is set to 7.0 shortcodes work correct but on versions 7.1 and 7.2 the shortcodes do not arrange the columns and the column's contents are one under the other. sample (php 7.0): [http://marcintafelski.pl/][1] and [http://marcintafelski.pl/kontakt][2] sample (php 7.2): [http://kapita.pl/][3] and [http://kapita.pl/kontakt][4] [1]: http://marcintafelski.pl/ [2]: http://marcintafelski.pl/kontakt [3]: http://kapita.pl/ [4]: http://kapita.pl/kontakt
27 Comments
SRuff
SRuff posted this 21 September 2018
Hi Dave,
Looks like you refer to the same issue here as in the topic https://answers.themler.io/questions/171179/no-more-shortcodes-now-what
Let's continue discussion in that topic.
I have the exact problem. I renewed my license and the update caused the error.
Warning: Illegal string offset 'width' in /home/__/public_html/plugins/content/themlercontent/lib/Shortcodes.php on line 1492
Is there a fix?
> Hi Dave, > > Looks like you refer to the same issue here as in the topic https://answers.themler.io/questions/171179/no-more-shortcodes-now-what > Let's continue discussion in that topic. > > Thank you, > Nettie I have the exact problem. I renewed my license and the update caused the error. Warning: Illegal string offset 'width' in /home/______/public_html/plugins/content/themlercontent/lib/Shortcodes.php on line 1492 Is there a fix? Thank you
DaveOzric
DaveOzric posted this 21 September 2018
No one knows when you removed this or if it's purely a PHP issue? The details are extremely simple. Read the initial post in this thread and you will see exactly what is wrong. The columns shortcode you had instructed us to use is no longer working with PHP 7.1 or above.
What else is there to tell you?
No one knows when you removed this or if it's purely a PHP issue? The details are extremely simple. Read the initial post in this thread and you will see exactly what is wrong. The columns shortcode you had instructed us to use is no longer working with PHP 7.1 or above. What else is there to tell you?
Support Team posted this 21 September 2018
Thank you all for your input. The shortcodes should work, so we will investigate the issue together with our developers. The question left now is whether anything has changed namely after the latest Themler update.
Hello, Thank you all for your input. The shortcodes should work, so we will investigate the issue together with our developers. The question left now is whether anything has changed namely after the latest Themler update. Sincerely, Nettie
souacz
souacz posted this 21 September 2018
This is issue specific for php. I did not update templates before before it came out, only upgraded the php version for domain. After this operation the columns showed up one under the other
DaveOzric
A fix would be nice so I do not have to update the site's I have used it on. Going forward I believe I will use only Bootstrap column divs. Although updating to a new version of Bootstrap will probably hose that up too.
I see, thank yo for your comments. We will update this topic as soon as there is information from our developers on the issue.
Hello, I see, thank yo for your comments. We will update this topic as soon as there is information from our developers on the issue. Sincerely, Nettie
mail152
mail152 posted this 18 October 2018
Do you have an update yet for the shortcodes.php?
Still got an error under PHP 7.1. and the shortcodes not work at all:
PHP Warning: Illegal string offset 'width' in /is/htdocs/wp12541520_O6HFRBX9R9/www/Theme/library/shortcodes.php on line 78
Best regards
Daniel
Do you have an update yet for the shortcodes.php? Still got an error under PHP 7.1. and the shortcodes not work at all: PHP Warning: Illegal string offset 'width' in /is/htdocs/wp12541520_O6HFRBX9R9/www/Theme/library/shortcodes.php on line 78 Best regards Daniel
