Problem with post header in blog style
jnskst
jnskst posted this 04 August 2015
Hi, I have a problem with post headers in joomla. In my blog style I show on the top the category description and below the related articles. My problem is, I want to show the post header means title of category and title of articles, but if I add the post header in themler it shows always the menu entry at first. I dont wan't this If I remove the header, it remove also the title which I still need. what can you suggest?
best regards
Jens
Hi, I have a problem with post headers in joomla. In my blog style I show on the top the category description and below the related articles. My problem is, I want to show the post header means title of category and title of articles, but if I add the post header in themler it shows always the menu entry at first. I dont wan't this If I remove the header, it remove also the title which I still need. what can you suggest? best regards Jens
jnskst
Please find the picture attached as an explanation.
"Beitragsblog" is the name of the menu entry. I don't wan't it!
"Hifi-Profis - Kein Geschäft wie jedes andere!" is the title of that category. Thats what I want.
"Techniker/in für den Bereich Hifi" in the related article below is ok!
If I try to remove the header, it will also remove the title of both.
Please find the picture attached as an explanation. "Beitragsblog" is the name of the menu entry. I don't wan't it! "Hifi-Profis - Kein Geschäft wie jedes andere!" is the title of that category. Thats what I want. "Techniker/in für den Bereich Hifi" in the related article below is ok! If I try to remove the header, it will also remove the title of both.
Stagger Lee posted this 04 August 2015
You have another problem there. It is something Themler do on default, dont know why.
Go to the Post header More options and set line-height the same for both Text and Link, rmove all other options from Paragraph. And set font-size, font-weight same for both.
it will remove this unnatural spacing and give you again perfect control with padding and margin for Post header.
But still, maybe you already dit it. Difficult to say from image. I write it for other people, just to be aware of this.
You have another problem there. It is something Themler do on default, dont know why. Go to the Post header More options and set line-height the same for both Text and Link, rmove all other options from Paragraph. And set font-size, font-weight same for both. it will remove this unnatural spacing and give you again perfect control with padding and margin for Post header. But still, maybe you already dit it. Difficult to say from image. I write it for other people, just to be aware of this.
jnskst
Thanks for the quick reply. I did all changes you suggested.
But the main problem is still there. I cant remove the Menu-Title without killing my Article Title for all articles below the category description.
Thanks for the quick reply. I did all changes you suggested. But the main problem is still there. I cant remove the Menu-Title without killing my Article Title for all articles below the category description.
Support Team posted this 06 August 2015
Hello Jens,
you may try to suppress the Title output under Blog Menu item Options. Or suppress article title output for certain articles.
I cannot provide more precise suggestion as I do no see the blog layout you're using.
If you cannot handle with it you may provide access to Joomla admin back end so we could log in and check the settings.
Hello Jens, you may try to suppress the Title output under Blog Menu item Options. Or suppress article title output for certain articles. I cannot provide more precise suggestion as I do no see the blog layout you're using. If you cannot handle with it you may provide access to Joomla admin back end so we could log in and check the settings. Regards, Aileen
