Problem checkbox not display
mateuszlasica
mateuszlasica posted this 24 September 2018
Hello.
I have a problem with the checkbox.
Radiobutton is not displayed.
It's only when I turn off two parameters in style that I see it but I can not turn it off in themler!
Please help!
Where to turn it off at Themler?
Hello. I have a problem with the checkbox. Radiobutton is not displayed. It's only when I turn off two parameters in style that I see it but I can not turn it off in themler! Please help! Where to turn it off at Themler?
Support Team posted this 24 September 2018
It is hard to tell what is causing this without access to the site. But based on the screenshot you shared you should be able to resolve this by adding this code in Themler -> Home -> Settings -> Additional CSS:
#form-checkbox-20 {
display:block!important;
position:relative!important;
If this doesn't help, please, provide temporary access to your site.
Hello, It is hard to tell what is causing this without access to the site. But based on the screenshot you shared you should be able to resolve this by adding this code in Themler -> Home -> Settings -> Additional CSS: #form-checkbox-20 { display:block!important; position:relative!important; } If this doesn't help, please, provide temporary access to your site. Gina Themler Support
