Language template woocommerce
andriel.schulze
andriel.schulze posted this 24 September 2018
I'm having a problem with a website / woocommerce that I'm developing. The site language is PT-BR, but buttons like ADD TO CART and BUY are in English on the front-end. Previously I was in pt-br as usual, but now it's in English, and I can not change it, can you help me?
Support Team posted this 25 September 2018
Hello Andriel,
Try checking translation files in Wordpress. Open translation file you're using (.po), find the Add To Cart key and change the translation text. Then you need to regenerate .mo file. You can do it all in PoEdit or download corresponding WP plugin, for example, Loco Translate.
Hello Andriel, Try checking translation files in Wordpress. Open translation file you're using (.po), find the Add To Cart key and change the translation text. Then you need to regenerate .mo file. You can do it all in PoEdit or download corresponding WP plugin, for example, Loco Translate. Gina Themler Support
