Hi.
Can't login inside Themler to save theme.
No response from account.themler.io.
Hi.
We are sorry for the issue, we will try to fix it as soon as possible.
Hi.
Thank you for fast solving, now works fine.
Hi. Thank you for fast solving, now works fine.You are welcome!
I've been having the same issue for the past 3 days.
I've been having the same issue for the past 3 days.I've been having the same issue for the past 3 days.
I do some test now, i can login and i can save, please try again
> I've been having the same issue for the past 3 days. I do some test now, i can login and i can save, please try againPlease... I can't log in too... I need help please!!!
Please... I can't log in too... I need help please!!!Hello,
We are sorry for the inconvenience. We have found the problem and will try to fix it as soon as possible. It is related to a security update in Google Chrome v80. Meanwhile please consider using Firefox for Themler.
The fix is available. It is recommended, to perform the following steps so that it is applied correctly.
For Themler on the hosted website please follow these steps:
1) Open this URL in Chrome:
chrome://appcache-internals
2) Open this URL in Chrome:
For Themler Desktop please try the following:
1) close Themler
4) start Themler again
