Update to Joomla 3.9 (include_path='.:/usr/lib/php7.1')
kunze
kunze posted this 30 October 2018
I have updated to 3.9. The Themler Onlie version can not be opened afterwards.
Error:
Fatal error: require_once (): Failed opening required '/homepages/34/d41418126/htdocs/../../administrator/includes/toolbar.php' (include_path = '.: / Usr / lib / php7.1') in /homepages/34/d41418126/htdocs/../../templates/tsk-sachsen/app/index.php on line 25
Could you please help me?
many Greetings
Martin
Hello, I have updated to 3.9. The Themler Onlie version can not be opened afterwards. Error: Fatal error: require_once (): Failed opening required '/homepages/34/d41418126/htdocs/../../administrator/includes/toolbar.php' (include_path = '.: / Usr / lib / php7.1') in /homepages/34/d41418126/htdocs/../../templates/tsk-sachsen/app/index.php on line 25 Could you please help me? many Greetings Martin
6 Comments
Support Team posted this 30 October 2018
We are sorry for the issue. We will try to fix it as soon as possible and will update this topic as soon as it is fixed.
Hello, We are sorry for the issue. We will try to fix it as soon as possible and will update this topic as soon as it is fixed. Sincerely, Nettie
sibren
sibren posted this 30 October 2018
Hi, You can fix the issue for now by copying a toolbar.php file from a Joomla 3.8.13 installation into the ./administrator/includes/ folder.
After doing this you should be able to edit you themler template again.
I have attached the file I have used for this
Hi, You can fix the issue for now by copying a toolbar.php file from a Joomla 3.8.13 installation into the ./administrator/includes/ folder. After doing this you should be able to edit you themler template again. I have attached the file I have used for this
matrix630307
matrix630307 posted this 30 October 2018
hi sibren
cool - thank's for your "help" to this time. hope themler crew will fix this in short time....
hi sibren cool - thank's for your "help" to this time. hope themler crew will fix this in short time....
Seppe
Seppe posted this 30 October 2018
Since Sibren already fixed it .... it will be ok for the developpers....
Support Team posted this 31 October 2018
Hi everyone,
We're preparing the update with the fix for this issue. It will be available ASAP.
In addition to this, we'll provide an instruction on what php files should be changed in order to start Themler and update it if you already updated Joomla.
Those who have not yet installed the updated Joomla will just need to update Themler first.
We apologize for the inconvenience.
Hi everyone, We're preparing the update with the fix for this issue. It will be available ASAP. In addition to this, we'll provide an instruction on what php files should be changed in order to start Themler and update it if you already updated Joomla. Those who have not yet installed the updated Joomla will just need to update Themler first. We apologize for the inconvenience. Sincerely, Olivia
The new update is here!
https://answers.themler.io/questions/173622/themler-hotfix-update-v-472-update-31-oct-2018
If you already updated Joomla to version 3.9 and encountered a problem with launching Themler please follow this instruction and then update Themler.
Hi, The new update is here! https://answers.themler.io/questions/173622/themler-hotfix-update-v-472-update-31-oct-2018 If you already updated Joomla to version 3.9 and encountered a problem with launching Themler please follow [this instruction](page:173620) and then update Themler. Sincerely, Olivia
