Sticky header - gap at top
eleanor
eleanor posted this 15 November 2018
Hiya
My sticky menu is working perfectly on all my pages except one area of my website.
It's the individual blog pages that aren't working.
Here's an example...
https://www.londoncarpetexpress.co.uk/carpet-blog/outwiththeold-inwiththenew
The menu scrolls up and when it should stick it jumps back down.
I've attached the theme.
Ideas?
Thank you.
Hiya My sticky menu is working perfectly on all my pages except one area of my website. It's the individual blog pages that aren't working. Here's an example... https://www.londoncarpetexpress.co.uk/carpet-blog/outwiththeold-inwiththenew The menu scrolls up and when it should stick it jumps back down. I've attached the theme. Ideas? Thank you.
Support Team posted this 15 November 2018
Hello Eleanor,
I don't see this issue happening in Themler with your attached theme on Post template, thus, I can't tell why this happens exactly, maybe investigating your live site in Themler would help.
Try adding this code to template.min.css:
.affix.bd-affix-3 {
    top: 0;
Hello Eleanor, I don't see this issue happening in Themler with your attached theme on Post template, thus, I can't tell why this happens exactly, maybe investigating your live site in Themler would help. Try adding this code to template.min.css: .affix.bd-affix-3 { top: 0; } Gina Themler Support
eleanor
eleanor posted this 16 November 2018
Hiya
Thank you for the CSS, that worked!
Brilliant as ever. :)
Kind regards
Eleanor
Hiya Thank you for the CSS, that worked! Brilliant as ever. :) Kind regards Eleanor
Support Team posted this 16 November 2018
You are welcome. Please feel free to contact us if any other questions appear.
You are welcome. Please feel free to contact us if any other questions appear. Sincerely, Nettie
avalynn1133
avalynn1133 posted this 15 January 2026
A common cause of a gap at the top with a sticky header is extra margin or padding on the first element below the header. Check your CSS for things like margin-top or padding-top on that section and adjust or override it.
If you’re also into Android mods and want to browse BR Mod APK info, check this out: BR Mod APK guide
Hope that helps!
A common cause of a gap at the top with a sticky header is extra margin or padding on the first element below the header. Check your CSS for things like margin-top or padding-top on that section and adjust or override it. If you’re also into Android mods and want to browse BR Mod APK info, check this out: [BR Mod APK guide][1] . Hope that helps! [1]: https://virtuallifeapk.com/br-mod-apk/
menuwendys10
menuwendys10 posted this 4 weeks ago
Issues like sticky header gaps at the top of a webpage are common in web design and often relate to CSS positioning, margins, or theme conflicts. Troubleshooting such problems improves user experience, much like how Wendy,s Menu ensures smooth navigation with well-structured and responsive design.
Issues like sticky header gaps at the top of a webpage are common in web design and often relate to CSS positioning, margins, or theme conflicts. Troubleshooting such problems improves user experience, much like how [Wendy,s Menu][1] ensures smooth navigation with well-structured and responsive design. [1]: https://wendysmenuinf.com/
